[Mapserver-users] TrueType Font and Label Angle
Daniel Morissette
morissette at dmsolutions.ca
Wed Jan 15 00:42:07 EST 2003
"Jonathan W. Lowe" wrote:
> For what it's worth, my installation on RedHat 8.0 didn't have the label angle
> problems, so it is possible to successfully compile the software on Linux. At
> one point in my efforts to overcome the label angle problems, I found a
> reference that said the mere presence of freetype2 might force the compiler to
> use freetype2 (the supposed culprit in the label angle problem) rather than
> freetype1. Do you have root access to the system on which you are compiling? I
> had to isolate libraries like gd and freetype in a local directory in order to
> be sure my compilation used exactly the libraries I intended it to use.
FYI there is a --enable-force-freetype1 configure switch in 3.6.x and
3.7 to try to force detection of Freetype 1 in priority over freetype 2
when a system has both. Starting with RH 7.x and 8.x this is very
useful if you want to compile with your own custom GD with freetype 1.3.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
