[Mapserver-users] Adding php_mapscript
Yewondwossen Assefa
assefa at dmsolutions.ca
Wed Jan 15 15:09:26 EST 2003
Windows binaries for the latest release of mapsevrer 3.6.4 are available on the download site for php4.2.3 and php4.3.0 :
http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.6.4-win32-php4.2.3-libwww.zip
http://www2.dmsolutions.ca/mapserver/dl/mapserver-3.6.4-win32-php4.3.0-libwww.zip
Later,
krung wrote:
> Hi Beth
> Did you use php_mapscript.dll the same version as your PHP? I went to dmsolution a few days ago, I couldn't find php_mapscript.dll with PHP 4.3.0 support.
> Krung.
> ---------- Original Message ----------------------------------
> From: Beth Baily <bbaily at CEMML.ColoState.EDU>
> Date: Wed, 15 Jan 2003 10:37:25 -0700
> >Listers,
> >I have installed and tested PHP4 on my Win2000 workstation with Apache
> >and cgi mapserver 3.5. PHP4 by itself works fine. I moved
> >php_mapscript.dll to the php4 extensions directory and set extension_dir
> >in php.ini to that directory. Then I used phpinfo_mapscript.php to test
> >it. The output I get in my browser is:
> >Warning: dl() [function.dl]: Unable to load dynamic library
> >'d:\php\php-4.3.0-Win32\extensions\php_mapscript.dll' - The specified
> >procedure could not be found. in d:\program files\apache
> >group\apache2\htdocs\phpinfo_mapscript.php on line 17
> >followed by the results from phpinfo().
> >When I first start my browser and try to run phpinfo_mapscript.php, I
> >get this error:
> >The procedure entry point zend_list_addref could not be located in the
> >dynamic link library php4ts.dll.
> >I can click on OK and then I see the results described above. I would
> >appreciate any help.
> >Thanks,
> >Beth
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
