[Mapserver-users] Fwd: html variables from map file
Lowell Filak lfilak at medinaco.org
Wed Jan 15 16:35:20 EST 2003
The following message was sent by Alexander   Shostko <shostko at ureach.com> on Wed, 15 Jan 2003 15:19:39 -0500.
> Thanks for your advice in advance.
> Is there a way to address variable defined in html file
> from the map file in Expression statement:
> for example
> if I want to choose which attribute in .dbf file should be
> chosen based on the value of select construct in html file
> EXPRESSION( $interval eq 1 )
>   EXPRESSION ([LEVEL] gt 1.0 ) ...
> EXPRESSION( $interval eq 3 )
>   EXPRESSION (LEVEL3] gt 1.0 ) ...
> end
> the interval comes from html file.
> I am afraid that mapscript is the answer for this issue
> Thank you very much again
> Alexander Shostko
> Simulation Technologies Co.
> Vienna, VA
