[Mapserver-users] TrueType Font and Label Angle
Pericles Nacionales
nacional at cbs.umn.edu
Mon Jan 13 16:13:29 EST 2003
Larry,
Did you try compiling GD and MapServer with the same freetype version?
I usually compile mine with version 1.3.1 and everything works just fine.
Here's what I do to compile Freetype 1.3.1 with MapServer:
./configure --enable-force-freetype1 --with-gd=static,../gd-1.8.4 ...
Then I edit the resulting Makefile and make sure that the GD line
contains "-DUSE_GD_TTF", and NOT "-DUSE_GD_FT".
As for GD, I compile my own version and link it statically to MapServer.
I just make sure to edit GD's Makefile and use -DHAVE_LIBTTF (and -lttf)
instead of -DHAVE_LIBFREETYPE (and -lfreetype).
I don't know if all these have anything to do with labels getting screwed
up but I've never had issues with Truetype fonts this way.
By the way, I use Gentoo Linux and Lycoris Desktop/LX. I don't have
Redhat 8 but I know my Lycoris binaries work properly on it (having used
it for a workshop at JPL).
Good luck!
-Perry N.
On Mon, 13 Jan 2003, Ellenbecker, Larry wrote:
> List,
> I'm trying to get true type fonts working with my application on Linux. The
> application is up a running on both Linux and NT. True type fonts are
> working just fine on NT, but on Linux I've had the following problems. My
> application is straight CGI.
> System Specs: RedHat 7.0 with freetype-1..3.1. freetype-2.1.2, gd-2.0.9
> and mapserver-3.6.1.
> After compiling and installing both freetype fonts and GD,
> I compiled mapsever and got the msGetLabelSize(): Could not find/open font.
> Initaially my application was sitting at:
> /var/www/html/simple with simple.map FONSET
> fonts/fonts.txt
> When I moved my fonts directory to /var/www/html/fonts and
> changed simple.map FONSET ../fonts/fonts.txt I was able to use true type
> font arial in my application. I then ran into the next issue with Label
> Angle. I couldn't get the labels to follow the appropriate line orientation
> as it does on my NT version. I researched the list and found Jonathan
> Lowe's "line layer label angle changes(solved)" . I've tried to follow
> these directions but am still unable to get the labels to plot with the
> correct orientation of the line. The BUFFER, BACKGROUNDSHADOWSIZE AND
> BACKGROUNDCOLOR create a background box oriented in the appropriate
> position but the text doesn't hit the background box.
> Has anyone got a sure fire method for resolving truetype
> label angle problems - I'd sure appreciate any assistance.
> Larry L. Ellenbecker
> GIS Systems Analyst
> Winnebago County
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
