[Mapserver-users] Re: PHP 4.3.0
pkishor_98 <pkishor at geoanalytics.com> pkishor at geoanalytics.com
Thu Jan 16 22:54:05 EST 2003
Hi Daniel,
Thanks for replying. Now that I know it works, here are the gory
details -- gcc 2.95 on OS X 10.2.3, PHP 4.3.0 built as CGI "--with-xml
--with-zlib --with-mysql --with-gd --with-png --with-jpeg --with-xml
--enable-wddx --enable-dbase --with-regex=system" and working fine.
Any idea why I am getting the following errors (reproducing only the
last bit) during make-ing Mapserver --
-I/Users/pkishor/Projects/mapserver/php-4.3.0/TSRM  -c -o
mapscript_i.o mapscript_i.c
/Users/pkishor/Projects/mapserver/mapserver-3.6.4/maptemplate.h:16:
warning: `inchesPerUnit' defined but not used
cc: -flat_namespace: linker input file unused since linking not done
cc   -o php_mapscript.so php_mapscript_util.o php_mapscript.o
mapscript_i.o  -L/Users/pkishor/Projects/mapserver/mapserver-3.6.4
-lmap          -ljpeg  -L/usr/local/lib -lpng -lz
-L/Users/pkishor/Projects/mapserver/mapserver-3.6.4/../gd-1.8.4 -lgd
-ljpeg  -L/usr/local/lib -lpng -lz -ljpeg   -lm
/usr/bin/ld: Undefined symbols:
_main
__convert_to_string
__efree
__emalloc
__estrdup
__object_init_ex
__zend_list_find
__zval_copy_ctor
_add_property_resource_ex
_add_property_zval_ex
_convert_to_double
_convert_to_long
_zend_error
_zend_hash_find
_zend_hash_get_current_data_ex
_zend_hash_get_current_key_ex
_zend_hash_internal_pointer_reset_ex
_zend_hash_move_forward_ex
__array_init
__estrndup
__object_init
__zend_list_addref
__zend_list_delete
_add_assoc_string_ex
_add_next_index_long
_add_next_index_string
_add_property_double_ex
_add_property_long_ex
_add_property_string_ex
_php_header
_php_printf
_php_write
_sapi_module
_zend_get_parameters
_zend_hash_index_find
_zend_hash_num_elements
_zend_list_insert
_zend_register_internal_class
_zend_register_list_destructors
_zend_register_list_destructors_ex
_zend_register_long_constant
_zend_wrong_param_count
make[1]: *** [php_mapscript.so] Error 1
--- Daniel Morissette <morissette at d...> wrote:
> "pkishor_98 " wrote:
> > I am getting a bunch of errors compiling ms3.6.4 (all related to
> > php_mapscript.so), and before I get any further, I would like to
find
> > out if the current PHP/Mapscript module work with PHP 4.3.0. Does
it?
> Yes it does work with PHP 4.3.0.  I haven't used it myself yet, but
> Assefa has built it with PHP 4.3.0 and I haven't heard of anything
> special.  This windows DLL for PHP 4.3.0 is on our download site.
