[Mapserver-users] Couldn't find gdal-config
Philipp Jacob philipp.jacob at geosysnet.de
Fri Jan 17 05:01:32 EST 2003
frauke.trurnit at gmx.de wrote:
>Hi Philipp,
>first you must implement the following instructions:
>cd /usr/local/src/gdal-1.1.7
>./configure
>make
>make install
>>> I installed gdal-1.1.7 and gdal-config can be found in /usr/local/bin/
Mentioning this, I intended to say that I've already done this.
Nevertheless 'configure' can't find gdal-config.
>>Hi all,
>>I'm trying to configure mapserver3.6.4 with the '--with-gdal' option.
>>I tried it with:
>>'--with-gdal'
>>'--with-gdal=/usr/local/bin/gdal-config'
>>'--with-gdal=/usr/local/src/gdal-1.1.7/apps/gdal-config'
>>But always the same problem, the configure script is unable to find
>>gdal-config.
>>Any ideas?
>>Thanks in advance.
>>Philipp
