[Mapserver-users] query result for a point
nida Khan
nida at webstar.co.uk
Mon Jan 20 07:40:02 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0172_01C2C081.0D6A9C40
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi Calin,
Thanx for your reply,
I tried tolerance 50 but still the same thing, query works only on =
polygon.
I also tried by plotting only points on the map, only one layer that =
means. :( still no luck.
here is def. of my layer in map file
# to disply postcode on map
LAYER # start of the "points" layer object
CONNECTIONTYPE postgis
NAME "points"
CONNECTION "host=3D34343 port=3D5432 user=3Dteest password=3Dtest =
dbname=3Dtest"
DATA "the_geom from points"
STATUS ON
TYPE POINT
METADATA=20
"DESCRIPTION" "DISTRICT"
"RESULT_FIELDS" "region"
END
CLASS
NAME "points"
COLOR 0 0 0
#OUTLINECOLOR 255 89 89
#SYMBOL 'circle'
SYMBOL 7
SIZE 8
END # end of class object
TOLERANCE 50
END # end of layer object
Many Thanks
Nida.
----- Original Message -----=20
To: nida Khan=20
Sent: Monday, January 20, 2003 12:19 PM
Subject: Re: [Mapserver-users] query result for a point
Hi Nida,
Try to use the TOLERANCE ... I set it to 50 pixels (TOLERANCE 50) and =
the query works fine...
Calin
To: Mapserver-users at lists.gis.umn.edu=20
Sent: Monday, January 20, 2003 10:58 AM
Subject: [Mapserver-users] query result for a point
Hi List,
I have a map file with some layers.=20
My query option works fine with all the polygon layers but it does =
not work for point.
For those points which are ploted on top of polygon, query display =
the polygon details,
and for the points outside the polygon, query display "no result =
found".
points layers is the top layer, so I dont understand why its =
querying the ploygon layer instead of points?
I really appreciate any input,
Many Thanks
Nida.
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT size=3D2>Hi Calin,</FONT></DIV>
<DIV><FONT size=3D2></FONT> </DIV>
<DIV><FONT size=3D2>Thanx for your reply,</FONT></DIV>
<DIV><FONT size=3D2>I tried tolerance 50 but still the same thing, =
query=20
works only on polygon.</FONT></DIV>
<DIV><FONT size=3D2>I also tried by plotting only points on the map, =
only one=20
layer that means. :( still no luck.</FONT></DIV>
<DIV><FONT size=3D2>here is def. of my layer in map file</FONT></DIV>
<DIV><FONT size=3D2># to disply postcode on map<BR></FONT><FONT =
size=3D2>LAYER #=20
start of the "points" layer object<BR> CONNECTIONTYPE =
postgis<BR> =20
NAME "points"<BR> CONNECTION "host=3D34343 port=3D5432 =
user=3Dteest=20
password=3Dtest dbname=3Dtest"<BR> DATA "the_geom from =
points"<BR> =20
STATUS ON<BR> TYPE POINT<BR> METADATA <BR> =
"DESCRIPTION" "DISTRICT"<BR> =
"RESULT_FIELDS"=20
"region"<BR> END<BR> CLASS<BR> NAME=20
"points"<BR> COLOR 0 0 0<BR> =
#OUTLINECOLOR=20
255 89 89<BR> #SYMBOL 'circle'<BR> =
SYMBOL=20
7<BR> SIZE 8<BR> END # end of class =
object<BR> =20
TOLERANCE 50<BR>END # end of layer object</FONT></DIV>
<DIV><FONT size=3D2>Many Thanks</FONT></DIV>
<DIV><FONT size=3D2>Nida.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Dcalin at internetgids.be =
href=3D"mailto:calin at internetgids.be">Calin D.=20
NITU</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A =
title=3Dnida at webstar.co.uk=20
href=3D"mailto:nida at webstar.co.uk">nida Khan</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Monday, January 20, 2003 =
12:19=20
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] =
query=20
result for a point</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hi Nida,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Try to use the TOLERANCE ... I set it =
to=20
50 pixels (TOLERANCE 50) and the query works =
fine...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Calin</FONT></DIV>
<DIV=20
<A title=3Dnida at webstar.co.uk =
href=3D"mailto:nida at webstar.co.uk">nida Khan</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
title=3DMapserver-users at lists.gis.umn.edu=20
href=3D"mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Monday, January 20, =
2003 10:58=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] =
query result=20
for a point</DIV>
<DIV><BR></DIV>
<DIV><FONT size=3D2>Hi List,</FONT></DIV>
<DIV><FONT size=3D2>I have a map file with some layers. =
</FONT></DIV>
<DIV><FONT size=3D2>My query option works fine with all the polygon =
layers but=20
it does not work for point.</FONT></DIV>
<DIV><FONT size=3D2>For those points which are ploted on top of =
polygon,=20
query display the polygon details,</FONT></DIV>
<DIV><FONT size=3D2>and for the points outside the polygon, =
query display=20
"no result found".</FONT></DIV>
<DIV><FONT size=3D2>points layers is the top layer, so I dont =
understand why=20
its querying the ploygon layer instead of points?</FONT></DIV>
<DIV><FONT size=3D2>I really appreciate any input,</FONT></DIV>
<DIV><FONT =
size=3D2></FONT> </DIV></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0172_01C2C081.0D6A9C40--
