[Mapserver-users] Wierd PostGIS Layer Error - msPOSTGISLayerWhichShapes()
Benjamin Wragg bwragg at tpg.com.au
Wed Jan 22 16:00:15 EST 2003
Testpoints is a table in the database with a geometry column. It's a
simple layer that contains 7 points. The geometry is held in the
"the_geom" field and when I do a select on the table in psql I can see
that in the "the_geom" field every record begins with "SRID=-1;POINT("
followed by the geometry.
Cheers,
Benjamin Wragg
-----Original Message-----
Sent: Thursday, 23 January 2003 7:14 AM
To: 'bwragg at tpg.com.au'
Subject: RE: [Mapserver-users] Wierd PostGIS Layer Error -
Benjamin,
is there a geometry columns table in your database? does testpoints have
a
record in the table with SRID set?
Dave
Sent: Wednesday, January 22, 2003 2:42 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Wierd PostGIS Layer Error -
Hi All,
I've just fired PostGIS up and I'm getting the following error when I
use the draw() method of the mapObj:
Warning: MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error
executing POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it
failed too). DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d()),'NDR'),OID::text from WHERE &&
setSRID('BOX3D(-180 -45,180 225)'::BOX3D, find_srid('','','') ) in
C:\MAB\Dev\mapscripttest\test.php on line 4
>From what I've learnt so far, it seems that this query is missing the
geometry columns. Any ideas why?
Heres the map file I'm using:
NAME TEST
EXTENT -180 -90 180 90
SIZE 400 300
STATUS ON
UNITS DD
IMAGECOLOR 255 255 255
SYMBOLSET symbols.sym
WEB
  MINSCALE 2000000
  MAXSCALE 50000000
  IMAGEPATH "c:/mab/dev/temp/"
  IMAGEURL "/ms_tmp/"
END
LAYER
    CONNECTIONTYPE postgis
    NAME "testpoints"
    # Connect to a remote spatial database
    CONNECTION "user=user password=password dbname=dbname
host=localhost"
    # Get the lines from the 'geom' column of the 'roads' table
    DATA "the_geom FROM testpoints"
    STATUS default
    TYPE POINT
    CLASS
	COLOR 255 0 0
    END
END
END
I've tried all different configurations in the map file but I don't
think this is the problem because the $map=ms_newMapObj('mapfile.map')
line of code is getting executed with no errors. Also the $map object
exists because I can print out some of the variables?
Any ideas?
Thanks,
Benjamin Wragg
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
