[Mapserver-users] Raster geotiff turns background yellow
randy james
rjames57 at yahoo.com
Tue Jan 28 16:30:12 EST 2003
Hi
--- Ed McNierney <ed at topozone.com> wrote:
> Randy -
> Can you describe exactly what you did differently
> between those two images?
Well the difference is:
the tif that does not work has: a 256 RGB,
colorinterp=palette, is projected on the fly, and is a
newer version of an orthophoto.
I have used tiff2bw and gdal_translate to make it
grayscale, so i have a few versions of the file (5),
and all make the same error.
> Can you reproduce the problem with a single MAP file
> in which the troublesome layer is turned on and off
> via a LAYER= querystring parameter?
I tried with one layer and the background mapserver
generates is a gray color.
Another thing the troublesome layer is just a test
before i load all the others in the set (60
orthophotos in aoa, and 49 already loaded in utm
projection)
> I'm suspecting that the image itself is NOT the
> problem at all, but that the yellow is an artifact
> of something else that's happening at the same time.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: randy james [mailto:rjames57 at yahoo.com]
> Sent: Tuesday, January 28, 2003 1:37 PM
> To: Mapserver Users
> Subject: RE: [Mapserver-users] Raster geotiff turns
> background yellow
> Hi List
> Well i am still having the problem of a projected
> geotiff file changing the output of the mapserver
> cgi:
> the background turns yellow.
> I've tried
> importing and than exporting the image through
> GRASS
> tiff2bw to ensure the file is grayscale
> upgraded to the remotesensing site version of GDAL
> 1.1.7.1 from the Mandrake 8.2 version of 1.1.7.
> The geotiff image seems to be exactly like the ones
> that do not cause the problem.
> i am including a couple of files from the tmp
> directory, one where the background is yellow and
> one
> where it is not.
> does anyone know what next i should check?
> > Randy -
> > Is it possible for you to make the GeoTIFF
> > available? Thanks.
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > (978) 251-4242
> > Sent: Monday, January 27, 2003 12:35 PM
> > To: Mapserver Users
> > Subject: Re: [Mapserver-users] Raster geotiff
> turns
> > background yellow
> > Hi List
> > I checked the geotiff file in the GIMP and it did
> > not
> > have any yellow in the image. But than i checked
> the
> > image created by Mapserver and it has the yellow
> > background on it. Soo i assume that the cgi is
> > creating the yellow. Also i noticed that the
> polygon
> > layer loaded before the geotiff has changed to the
> > grayscale color of the geotiff.
> > I am sending the rendered imaged created by
> > mapserver
> > cgi for review.
> > Cheers
> > Randy
> > --- woodbri at swoodbridge.com wrote:
> > > Randy,
> > > I assume that the color change is taking place
> > when
> > > view in a
> > > browser? Have you tried to view it in an image
> > > viewer?
> > > Sometimes the browser pre allocates an bunch of
> > > colors and when you
> > > load the geotiff, it does not have enough slots
> in
> > > the color lookup
> > > table and has to assign the additional colors to
> > > existing ones. Some
> > > software is better at this than others, but it
> is
> > > typically the
> > > reason why your get the type of color change you
> > > described.
> > > -Steve W.
> > > On 24 Jan 2003 at 14:51, randy james wrote:
> > > > Hi list
> > > > Has anyone experienced problems with a geotiff
> > > file
> > > > making the image background turn yellow? (or
> any
> > > > color)
> > > > The orthophoto (geotiff) that causes the
> problem
> > > is my
> > > > fist attempt at projecting a raster on the
> fly.
> > I
> > > have
> > > > tried importing the ortho into GRASS and than
> > > > exporting it again, but it did not make a
> > > difference.
> > > > The gdalinfo utility output is quite large for
> > the
> > > > ortho causing the problem, but once its
> exported
> > > from
> > > > GRASS it is the same as the orthos that work
> (i
> > > think)
> > > > I'm wondering if its something to to with
> > > projecting a
> > > > raster or is it the file format. I will read
> > and
> > > try
> > > > the gdal_translate utility next i guess
> > > > MapServer version 3.6.4 OUTPUT=PNG OUTPUT=JPEG
> > > > OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=TTF
> > > > SUPPORTS=WMS_SERVER INPUT EPPL7 INPUT=JPEG
> > > > INPUT=POSTGIS INPUT=GDAL INPUT=SHAPEFILE
> > > > Cheers
> > > > Randy
> > __________________________________________________
> > > > Do you Yahoo!?
> > > > Yahoo! Mail Plus - Powerful. Affordable. Sign
> up
> > > now.
> > > > http://mailplus.yahoo.com
> > > > Mapserver-users mailing list
> > > > Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> > Do you Yahoo!?
> > Yahoo! Mail Plus - Powerful. Affordable. Sign up
=== message truncated ===
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now.
