[Mapserver-users] why a segfault with mapserv but shp2img works fine?
Sean Gillies
sgillies at frii.com
Thu Jan 30 19:14:46 EST 2003
On Thursday, January 30, 2003, at 04:58 PM, Daniel Morissette wrote:
> Sean Gillies wrote:
>> I've built mapserv and shp2img from a very recent CVS checkout. While
>> testing, I've found that shp2img works fine with my map file.
>> However,
>> when testing mapserv from the shell using the REQUEST_METHOD and
>> QUERY_STRING environmental variables (same map file), I get a
>> segmentation fault. My map has a single raster layer, a GeoTIFF that
>> I'm accessing with GDAL.
>> Can anyone briefly summarize the differences in the way shp2img and
>> mapserv work, and why the latter might be more prone to a segfault?
> Well, mapserv does all sorts of things that shp2img doesn't worry
> about. Think about all the template stuff (were you using mode=map or
> the default mode=browse ?), the QUERY_STRING parsing, turning layers on
> and off, temporary image files creation for elements found in the
> template, etc.
> A crash is always an important thing to fix IMO. If you can get a
> stack
> dump in GDB after the crash and provide more details to reproduce it
> then please file a bug in bugzilla with all that information.
> BTW, there is a (undocumented) way to test with mapserv at the
> command-line without having to set the QUERY_STRING and REQUEST_METHOD
> env. vars. You can use this:
> ./mapserv "QUERY_STRING=map=/path/to/mymap.map&mode=map&..."
> Daniel
The problem was in the web block of my map file. Doh! Thanks for the
suggestions. Cheers,
S.
