[Mapserver-users] RE: help with oid
ryanne cruz
ryanne.cruz at up.edu.ph
Fri Jan 31 00:47:46 EST 2003
hi list.
does anyone here know of a site that discusses oid? or can anyone here explain
to me what oid is and how it is used?
i am trying to set the data of a layer with a subselect as its argument.
example is:
$wind->set(data,"geom from (select geom AS geom from wind where
provinceid=$provid and distance(wind.geom,(select geom from municipality where
munprovid=$munprovid))<=0)");
but it results to an error:
Warning: MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error
executing POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed
too). DECLARE mycursor BINARY CURSOR FOR SELECT
watt_m2::text,asbinary(force_collection(force_2d(geom)),'NDR'),OID::text from
(select geom AS geom from wind where provinceid=1 and
distance(wind.geom,(select geom from municipality where munprovid=1))<=0)
WHERE geom && setSRID('BOX3D(118.267071942857 9.300063,118.638417057143
9.670539)'::BOX3D, find_srid('','windcipality','geom') )
and when i tried this:
where provinceid=$provid and distance(wind.geom,(select geom from municipality
where munprovid=$munprovid))<=0) as new_table using unique mun using
SRID=-1");
it reults to this error:
MapServer Error in msPOSTGISLayerWhichShapes(): prep_DB:Error executing
POSTGIS DECLARE statement (0.6 failed - retried 0.5 and it failed too).
i was thinking that the solution may be with using an oid but i'm not sure
what it is and how it works.
help!?
ryanne
