[Mapserver-users] PHP undef WAS: Memory Leak?
Lowell Filak lfilak at medinaco.org
Fri Jan 31 12:09:30 EST 2003
I will have to forward that request back to the list for the PHP folks to answer.
Anyone who can help, please reply to germangutierrezg at yahoo.es .
Thank you.
The following message was sent by "Juanse" <georef at tie.cl> on Fri, 31 Jan 2003 10:40:56 -0300.
> yes it is, but how to undef/close/destroyed? which command it is not in the
> docs.
> juanse
> temuko-chile
> ----- Original Message -----
> From: Lowell Filak <lfilak at medinaco.org>
> To: Juanse <georef at tie.cl>; Mapserver-Users
> <mapserver-users at lists.gis.umn.edu>
> Sent: Friday, January 31, 2003 10:38 AM
> Subject: Re: [Mapserver-users] Memory Leak?
> > Shot in the dark, but is there a possibility that after a map is created
> the mapObj is not being undef/closed/destroyed and that is the leak your
> seeing?
> > Lowell F.
> 2003 10:27:27 -0300.
> > > Hi everyone
> > > We have build this "mapmaker machine" scripting mapserver with php.
> > > The mapmaker machine need to do 2322 maps, comprised of a.- the map, b
> the
> > > legend, c.- the reference map.
> > > The application created the regional map (10 layers, 2 with thematic
> clases)
> > > then centers over the specified spot (center of each of 2322 polygons in
> one
> > > of the layers stored in postgresql).
> > > Then mapserver render the 3 images (png) and stores the *.png files in a
> > > file and the file names in the speceified columns in the postgresql
> table.
> > > if one check the process (top) the memory fill up after 90 spots, and
> then
> > > the whole machine work very slowly (20 maps per night). At this speed we
> > > need more than a 100 days to finish?
> > > Is there any command to free mapserver from memory? Does mapserver have
> any
> > > know memory leaks?
> > > Juanse
> > > temuko-Chile
> > > Outgoing mail is certified Virus Free.
> > > Checked by AVG anti-virus system (http://www.grisoft.com).
> > > Version: 6.0.445 / Virus Database: 250 - Release Date: 21/01/03
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
