[Mapserver-users] centering labels
Jim Burnett
r000t at adelphia.net
Fri Jan 31 12:27:37 EST 2003
Ok I tried that and it got a little better but here is another screenshot.
They still seem scattered
Of and FYI I turn this layer ON dynamically. Do I need to do something with
position?
http://www.freegishosting.com/tmp/1044034021.jpg
or just goto
http://www.freegishosting.com/va_washington.php
to paly with it. Make sure you turn on the parcel label layer.
-Jim
LAYER
NAME ParcelLabels
TYPE polygon
STATUS Off
DATA parcels
LABELITEM DXF_TEXT
CLASSITEM 'DXF_TEXT'
CLASS
EXPRESSION /./
NAME 'featureid'
#COLOR 0 0 0
OUTLINECOLOR 0 0 0
NAME 'streetnameid'
LABEL
PARTIALS true
COLOR 255 255 255
TYPE bitmap
POSITION auto
PARTIALS FALSE
END
END
TOLERANCE 0
END
----- Original Message -----
From: "Daniel Morissette" <morissette at dmsolutions.ca>
To: "Jim Burnett" <r000t at adelphia.net>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Friday, January 31, 2003 11:10 AM
Subject: Re: [Mapserver-users] centering labels
> > Jim Burnett wrote:
> > I'm trying to get my labels to center on my parcel layer. The layer is
> > a polygon layer.
> > Here is my layer def. And a screenshot of what is happening.
> > LAYER
> > NAME ParcelLabels
> > TYPE line
> You write that the layer is a polygon layer but your LAYER defn uses
> TYPE LINE, so the labels are placed along the lines (polygon
> boundaries). Changing to TYPE POLYGON will probably do what you need:
> place the labels at the polygon centers.
> Daniel
> Daniel Morissette morissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
