[mapserver-users] SWF output demo site?
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jul 1 12:00:43 EDT 2003
Hi Daniel,
I thought with SWF less frequent client-server contact is needed. So e.g.
zoom in does not require a new request. But after zooming in it seems like
a new map is retrieved from the server. Or is the client busy with zooming
in on the SWF image when it says retrieving image? How does this work, is
my statement only valid for vector SWF layers?
Thanks,
Bart
On Tue, 01 Jul 2003 11:56:24 -0400, Daniel Morissette
<morissette at dmsolutions.ca> wrote:
> Bart van den Eijnden wrote:
>> does anybody know about a Flash demo site in which mapserver with SWF
>> output is used?
> There's one at http://www.mapsherpa.com/make_a_map/ ... there are both
> HTML versions and Flash versions of the same app.
> A few quick notes:
> - The Flash version requires the Flash 6 plugin, you'll get an empty
> window if you use Flash 5.
> - The HTML version has a few glitches when you try to place points on
> the map... should be fixed soon.
> Daniel
