[Mapserver-users] Error with Demo-Package
Vincent Schut
schut at sarvision.com
Wed Jul 2 10:27:47 EDT 2003
short answer: search the mailing list archives
(http://mapserver.gis.umn.edu/cgi-bin/wilma/mapserver-users) for
'ctyhwy.gif'. This will give you plenty of messages about the same issue.
Longer answer: the demo is old, from the time gif wasn't copyrighted (or at
least unisys didn't force their copyrights on it). Mapserver uses libgd to
read/render graphics, which doesn't do gif anymore unless you have a special
patched version (for which you officially require a license). The demo should
be updated.
Workaround: convert the gif's to png and change the refenrence to these gifs
in the map files to the new png files.
Cheers,
Vincent.
On Wednesday 02 July 2003 15:43, stefan.albers at kreis-steinfurt.de wrote:
> Hi
> I've installed mapserver 3.6 on linux machine.
> Every things works perfectly well. When I run ..../cgi-bin/mapserv,
> I've got the following answer : No query information to decode.
> QUERY_STRING is
> set, but empty.
> If I understand well it means that mapserver is correctly installed
> Am I right ?
> I've downloaded the demo. When I run the demo_init.html I get the following
> Error
> msLoadMap(): General error message. Undefined symbol "symbols/ctyhwy.gif"
> in class 0 of layer ctyrdln3_anno.
> Any suggestions ?
> Stefan
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
