[Mapserver-users] python mapscript
Michael Schulz
mschulz at webgis.de
Wed Jul 2 11:14:28 EDT 2003
i have a question concerning the new error handling code in python
mapscript. While it is very good that mapscript now throws real
meaningful exceptions for a lot of errors, it is somewhat annyoing that
e.g. queryByPoint also gives an error when no records where found. What
would be the correct way to change this behaviour?
A bit more background information why this behaviour is annoying me (for
those using python mapscript in the zmapserver environment): i am
working on implementing query mechanisms in zmapserver, and in the
combination zope-zmapserver-python/mapscript it seems, that i am not
able to catch this exception correctly. Even worse, the zope process
gets killed (although an error should be raised, the zope process
segfaults). Well, as you might assume this is not the intended
behaviour. Hmm, any ideas, where to start looking?
TIA, Michael
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
Sautierstr. 38, 79104 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de
