[Mapserver-users] mapscript 3.7 $layer->draw() problems
Vincent Schut
schut at sarvision.com
Wed Jul 2 12:26:07 EDT 2003
Bart,
according to the php_mapscript classes guide, you will have to add some
arguments to rectangle->draw():
int draw(mapObj map, layerObj layer, imageObj img,
int class_index, string text)
Draws the individual rectangle using layer. The class_index is used
to classify the rectangle based on the classes defined for the layer.
The text string is used to annotate the rectangle.
Returns MS_SUCCESS/MS_FAILURE.
In your case this would become something like
$rectangle->draw( $wvimap, $wvilayer, $wviimg, 0, '' );
I guess you will have to experiment a bit with this. I have never used it,
actually. Don't forget to save the image *after* this rectangle drawing,
instead of before.
Cheers,
Vincent.
On Wednesday 02 July 2003 17:39, Bart van Heijningen wrote:
> Hi all,
> I use Mapserver 4 with php mapscript
> Here's the thing,
> I am trying to draw newRectObj() on a map.
> The size and position are generated from mysql
> However I think I am missing something.
> What am I doing wrong here. I have been struggling with this for a few days
> now, help would be higly appreciated.
> Thanks,
> Bart
> // the map
> $wvimap = ms_newMapObj("rdm3.map");
> $wvimap->selectOutputFormat('png24');
> $wviimg = $wvimap->draw();
> $imageobject = $wviimg->saveImage(test);
> // get correct layer
> $wvilayer = $wvimap->getLayerByName("$bleble");
> //$layerhandle = $wvilayer->open('$shpFname',1);
> // Zoek in deze layer de eerste class
> $classObj = $wvilayer->getClass(0);
> echo "classobject = $classObj<br>\n";
> $wvilayer->set("name", "$bleble");
> $wvilayer->set (status,MS_ON);
> $wvilayer->set (type,MS_POLYGON);
> $wvilayer->set (classitem,$classObj);
> $wvilayer->set (labelitem,"WVI");
> $wvilayer->set (data,"$shpFname");
> $wvilayer->draw($wvimap,$classObj);
> // Declaration of the rectangle object
> $rectangle = ms_newRectObj();
> // Here I calculate the values of the rectangle
> $rectangle->set("minx",($hshift+($measurements)*($rd_x)));
> $rectangle->set("miny",(($vshift+($measurements)*($rd_y))));
> $rectangle->set("maxx",(($hshift+(($measurements)*($rd_x)+($barwidth)))));
> $rectangle->set("maxy",(($measurements)*($rd_y) +
> (($maxbarheight/$maxvalue)*($measurements))+($barminheight)));
> echo "minx = $rectangle->minx<BR>\n";
> echo "miny = $rectangle->miny<BR>\n";
> echo "maxx = $rectangle->maxx<BR>\n";
> echo "maxy = $rectangle->maxy<BR>\n";
> // the following draw Mapserver does not like.
> I cannot find any good examples how the draw for this rectobject should be
> used.
> $rectangle->draw();
> the mapfile layer I want to use for displaying the rectObJect
> LAYER
> NAME "Ce-141"
> TYPE polygon
> STATUS ON
> CLASS
> NAME "Ce-141"
> COLOR 253 132 115
> BACKGROUNDCOLOR 253 132 115
> SYMBOL 'circle'
> LABEL
> TYPE TRUETYPE
> ANTIALIAS FALSE
> FONT arial
> COLOR 0 0 0
> BACKGROUNDCOLOR 254 254 254
> SIZE 6
> # ANGLE 45
> POSITION uc
> # buffer 2
> END
> END
> END
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
