[Mapserver-users] Oracle Spatial
Bart van den Eijnden bartvde at xs4all.nl
Wed Jul 2 14:21:52 EDT 2003
Hi Zamil,
otn (Oracle technology network) is the best site for Oracle information.
Oracle itself has a tool to import shapefiles into Oracle Spatial.
http://otn.oracle.com (you can register for free)
The easiest to use is the built-in Oracle Spatial support. To use the
support through OGR, you have to compile OGR against the Oracle client
library.
See also the mapserver wiki Oracle Spatial page:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?OracleSpatial
Best regards,
Bart
On Wed, 2 Jul 2003 12:03:19 -0600, Zamil Murji <Zamil.Murji at divestco.com>
wrote:
> Hello list,
> I want to use MapServer to draw an Oracle Spatial layer, however, I have
> never used Oracle Spatial. I have some questions I am sure you will be
> able to answer.
> 1) What utilities are available to import a shapefile into an Oracle
> Spatial database? Where can I download them from? 2) Need to know some
> good sites on how to setup Oracle 8i with the Spatial component, and I
> need a quick tutorial on how to create a table, alter a table, insert and
> select from that table. Any good sites?
> 3) I read on the newsgroup that there are two ways to go about this. One
> is to use the built in oracle spatial support and the other is to use
> ogr. I am running Apache on a windows 2000 box, what way is the best to
> go, easiest to setup?
> Thanks for your help
> Zamil
> -----Original Message-----
> From: Eduardo Patto Kanegae [mailto:eduardo at linkgeo.com.br]
> Sent: Wednesday, June 25, 2003 8:44 AM
> To: mapserver-users at lists.gis.umn.edu
> Cc: niklas "wörmann
> Subject: Re: [Mapserver-users] running v4 beta as a command line tool
> I've tested on MapServer 3.6.4 for Windows, using:
> $ mapserv "QUERY_STRING=map=c:\test\mymap.map&mode=map&foo=...." >
> but if you try to open "myresult.gif" it crash...
> so I opened this file with a text editor and deleted the first two
> lines(the headers), then it works!
> regards
> http://www.linkgeo.com.br
> ***Fim da Mensagem / End of Message ***
> On Wed, 25 Jun 2003 14:43:41 +0200, Vincent Schut <schut at sarvision.com>
> enscreveu:
>> De: Vincent Schut <schut at sarvision.com>
>> Data: Wed, 25 Jun 2003 14:43:41 +0200
>> Para: niklas wörmann <nwoe at privat.utfors.se>,   <mapserver-
>> users at lists.gis.umn.edu>
>> Assunto: Re: [Mapserver-users] running v4 beta as a command line tool
>> On Wednesday 25 June 2003 10:06, niklas wörmann wrote:
>> > Hi!
>> > i am trying to track down the reason mapserver isn´t working on my
>> windows
>> > 2000 server.
>> > i remember seeing somewhere that it was indeed possible to run
>> mapserver as
>> > a command line tool, specifying a map file and an output file
>> > anyone know the syntax for this?
>> On linux:
>> ./mapserv "QUERY_STRING=map=/path/to/your/mapfile.map&mode=map"
>> This will output headers + image data to stdout (on linux). Probably on
>> windows your executable is not named mapserv but something like
>> mapserv.exe? And use \ instead of / I think.
>> you cannot just save the output as image file because the headers are in
>> the output too.
>> But you can see if it outputs something (lots of ascii: image), or gives
>> an error.
>> To see the image: type in your browser:
>> http://localhost/cgi-bin/mapserv?map=/path/to/your/mapfile.map&mode=map
>> change / in path to \ if on windows?
>> Regards,
>> -- ______________________________________
>> Vincent Schut
>> Sarvision B.V.
>> Wageningen, The Netherlands
>> www.sarvision.com
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
