[Mapserver-users] adding RASTER Layer
Dylan Keon
keon at nacse.org
Wed Jul 2 15:42:06 EDT 2003
Brock,
Syntax for OFFSITE changed in 4.0. OFFSITE now takes an RGB value
instead of a single class index value. So, for example, if you're
trying to make black pixels transparent you would now use "OFFSITE 0 0
0" instead of "OFFSITE 0" (assuming class 0 was assigned to black pixels).
You could first try commenting out just the OFFSITE line to see if you
get anything...
--Dylan
Brock Murch wrote:
> Lo all:
> I seem to have stumbled into a problem. I am working throught the tutorial
> and have had much success, however, I can't seem to make the s2ex3 raster
> layer work. If I comment out the:
> #LAYER # Shaded Relief Raster
> # NAME "relief"
> # DATA "raster/shdrlfi020g_ugl.tif"
> # STATUS DEFAULT
> # TYPE RASTER
> # OFFSITE 0
> #END
> it works fine.
> However, if the layer is place I get no image, just a small vertical line
> (probably the border). I am using the newest version of mapserver.
> mapserv -v
> MapServer version 4.0-beta1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE
> gdal-config --formats
> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 bsb xpm sdts raw dted mem jdem
> envisat elas fit vrt usgsdem l1b nitf bmp hdf4 gif jpeg png
> I have tried it with my own data too. png format with a png world file
> following the above map file format with the same results.
> What am I missing? I'm not sure what to try next. Any thoughts would be
> greatly appreciated.
Dylan Keon
GIS/Database Specialist
Northwest Alliance for Computational
Science and Engineering (NACSE)
Oregon State University
Corvallis, OR 97331
keon at nacse.org (541) 737-6608
