[Mapserver-users] ActiveX IIS and Mapscript.
Dean Dean
Thu Jul 3 00:49:36 EDT 2003
Hello all,
I apologise if this has been covered before but I have searched the archives
and can not find anything recent.
Basically what I want to do is get a Mapscript application working with IIS
without resorting to having to install PHP or perl and preferably without
needing a java engine installed either. The Mapscript application will
basically read from catalogue and present the maps.
So -
Is there a COM component around that can be used within ASP. the archives
suggest a demand for, and some work being completed towards an ActiveX
component bit this seems to have petered out. (What happened?)
Does anybody have any compiled JAVA components to work on windows, with the
precompiled Mapserver Binaries from the mapserver site ? Has anybody
successfully compiled them using Borland C++ (Command Line)? Am I setting
myself up for a fall suggesting that I will have a go at creating them. (I
am not a C/C++ Programmer but have done a reasonable amount of
programming in other languages).
Any advice will be appreciated.
Thanks
Dean Taylor
Data Systems Engineer
Karjeni Pty Ltd
www.karjeni.com.au
