[Mapserver-users] Problem with Perl Mapscript
Lowell Filak lfilak at medinaco.org
Thu Jul 3 08:58:10 EDT 2003
For the version your using the documentation is correct.
For your
$image->saveImage($image, $image_path.$image_id, $mapscript::MS_PNG,
$map->{transparent}, $map->{interlace}, $map->{imagequality});
call change it to
$image->saveImage($image_path.$image_id,
$mapscript::MS_PNG,$map->{transparent},$map->{interlace},0);
imagequality has no effect on anything but JPEG and the usage message
that you received that included "self" is from the SWIG code and is not
actually part of the Perl call, for "$image->" indicates "self".
I will hopefully have time later today to take a longer look.
HTH
Lowell
The following message was sent by AMC Story <s9646183 at sms.ed.ac.uk> on
Thu, 03 Jul 2003 12:41:52 +0100 (BST).
> Hi everyone,
> Following my question about using JavaScript/MapScript to develop the
standard
> MapServer interface, I've now decided to try to use both, and have got
the Perl
> MapScript module working on our apache server.
> My problem is that most of the documentation and examples are for PHP
> MapScript.  Having only a list of constructors/methods etc for each
object type
> is helpful to a point, but this doesn't tell me how I should be
putting them
> together to get something to actually work!  I've been trying to
convert the
> PHP MapScript by Example HOWTO into perl, using Steve Lime's
mapquakes.pl as a
> guide.
> My first problem is that perl mapscript doesn't seem to have a direct
> equivalent of the saveWebImage method.  Is this correct?  In the
absence of
> such a method, I've been trying to use the saveImage method, but here
I seem to
> be running into problems.  If you look at the way I've called the
method (see
> code below), then maybe you could suggest what I'm doing wrong.
> In the first case (ie. using mapscript::msSaveImage(...)), I get the
error
> message "Type error in argument 1 of msSaveImage. Expected
_p_gdImagePtr..."
> when I run the program at the command line.  In the second case, using
$image-
> >saveImage(..), I get the following usage message "Usage:
imageObj_saveImage
> (self,filename,type,transparent,interlace,quality);".  This has
confused me
> because this isn't the argument list given in the documentation.
> If anyone has some simple, step by step examples of how to build up
> applications using Perl MapScript I'd be really interested in having a
look.
> Many thanks,
> Ali
> #!/usr/local/bin/perl -w
> #playing around with mapscript
> #use mapscript;
> use CGI qw(:standard);
> use mapscript;
> $cgi = new CGI;
> $map_file = "/usr/local/apache/local-bin/s9646183/mapscript/quakes.map";
> $image_path = "/usr/local/apache/htdocs/tmp/";
> $image_url = "/tmp/";
> $image_id = $$ . time() . ".png";
> $map = new mapscript::mapObj($map_file);
> $image = $map->prepareImage();
> $layer = $map->getLayerByName('countries');
> $layer->draw($map, $image);
> mapscript::msSaveImage($image, $image_path.$image_id,
$map->{imagetype}, $map->
> #$image->saveImage($image, $image_path.$image_id, $mapscript::MS_PNG,
$map->
> print $cgi->header();
> print $cgi->start_html(-title=>'Map 1: Perl Mapscript Test');
> print "<p>This is just a test</p>";
> print "<center><input type=\"image\" name=\"map\"
src=\"". $image_url .
> $image_id ."\"><br>";
> print $cgi->end_html();
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
