[Mapserver-users] Gmap under mapserver 4
woodbri at swoodbridge.com
Sun Jul 6 11:07:34 EDT 2003
Someone just posted a response this same question. Maybe it was on
the maplab list. Anyway, I thing you need to change the line to read:
$oLayer->open();
The parameter is no longer used as the info is passed via the Layer
object.
-Steve W.
On 4 Jul 2003 at 16:29, Bart van Heijningen wrote:
> Hi,
> I wonder if anyone here can help me with the next question.
> I am using mapserver 4 and try to get the gmap demo to work. All seems
> fine but I cannot seem to be able to get the querying right. It simply
> does not work. Maybe someone knows what the problem is? Somehow it no
> longer seems to be happy with the dbf file under Mapserver4. Looks
> like it does not like the amount of return fields from the query.
> Error:
> Warning: Wrong parameter count for open() in
> /www/htdocs/atmspoc/htdocs/poc_gmap75.php on line 698
> Fatal error: MapServer Error in msLayerGetShape(): Shapefile layer has
> not been opened. in /www/htdocs/atmspoc/htdocs/poc_gmap75.php on line
> 729
> Here is the gmap file the last line
> ¨$oLayer->open($gpoMap->shapepath);¨ produces the error.
> for($iLayer=0; $iLayer < $gpoMap->numlayers; $iLayer++)
> $oLayer = $gpoMap->GetLayer($iLayer);
> $numResults = $oLayer->getNumResults();
> if ($numResults == 0)
> continue; // No results in this layer
> // Open layer's table... take the list of fields to display
> from
> // the "HEADERRESULT_FIELDS" metadata in the layer object.
> $selFields = explode(" ",
> $oLayer->getMetaData("RESULT_FIELDS"));
> Thanks,
> Bart
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
