[Mapserver-users] ECW in Mapscript 4.0
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Jul 4 09:23:58 EDT 2003
I have just tested the php_mapscript_40.dll with a couple of ECW file
and I was able to display them properly. Could you contactes me off the
list, I will send you the tests that I made and see if you have the same
results.
Later,
braulioen at ono.com wrote:
>Hi at all,
> I'm using now the version 4.0 of Mapscript and the layer Raster
>ECW does not visualize. I've installed the ECW dll's that accompany
>php_mapscript_40.dll and the rest of dll's.
> The configuration of my file MAP has not changed, follows just as
>with previous version 3.6. Which can be the problem?
>Thanks in advance.
>Braulio.
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
