[Mapserver-users] can't connect postgis
=?gb2312?q?Chen=20Fu?= novalet at yahoo.com.cn
Mon Jul 7 07:51:05 EDT 2003
Hi!
I have some troubles in connecting postgis. As a
newbie , i don't know what's up :<
PostGis seems work fine in psql, i manually insert
some geometry data.
chenfu=# select * from test;
 id |  name  |                geom
  1 | geom 1 | SRID=-1;POINT(1 1)
  2 | geom 2 | SRID=-1;LINESTRING(1 2,2 3)
  3 | geom 3 | SRID=-1;POLYGON((2 1,3 1,3 3,2 1))
the database call chenfu and user is postgres,
password is also postgres. (I confirm password several
time after i find connection failed)
I build mapserver with postgis.
[root at cbers mapserver-4.0b]# ./shp2img -v
MapServer version 4.0-beta1 OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP SUPPORTS=FREETYPE INPUT=TIFF INPUT=EPPL7
INPUT=JPEG INPUT=POSTGIS INPUT=SHAPEFILE
Then I try a simplest map file
MAP
  NAME APPLE
  STATUS ON
EXTENT  -10 -10 10 10
UNITS METERS
SIZE 100 100
IMAGETYPE PNG
LAYER
CONNECTIONTYPE postgis
NAME "test"
CONNECTION "user=postgres password=postgres
dbname=chenfu host=localhost"
DATA "geom FROM test"
STATUS ON
TYPE LINE
END
END # Map File
But when i try shp2img on this map.
the result is
msDrawMap(): Image handling error. Failed to draw
layer named 'test'.
My platform is redhat8.
Do you know what's wrong? any suggestion is welcome!
Thank you in advance!
Remote Scensing Satellite Ground Station
Chinese Academy of Science
_________________________________________________________
Do You Yahoo!?
¹úÄÚµçÓÊÓû§·´À¬»øµ÷²éÀ­¿ªá¡Ä»
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.tech.yahoo.com/zhuanti/laji/index.html
