[mapserver-users] PDF output error
Bart van den Eijnden
bartvde at xs4all.nl
Tue Jul 8 13:31:31 EDT 2003
Hi list,
I have a problem using the PDF output. When I open/download the file I get
an error from Adobe Acrobat that the file is damaged and cannot be
repaired. I use the 4.0 beta1 version from the website. The error occurs
both on raster files and on vector files as input data.
This is the URL on which you can download the pdf (changing format into gif
will show the map):
http://fana.geodan.nl:83/cgi-
bin/bart/mapserv/mapserv_gif.exe?map=C:\Program%20Files\Apache%20Group\Apache2\htdocs\bart\geostreets.map&version=1.0.7&wmtver=1.0.7&layers=layer_1,layer_2,layer_3,layer_4,layer_5,layer_6&styles=default,default,default,default,default,default&bbox=120630,487143,121965,487670&width=890&height=352&format=pdf&exceptions=WMS_XML&transparent=True&request=map&t=63192866453163&srs=epsg:28992
Any ideas what is wrong?
Bart
