[Mapserver-users] queries - mapserver is "hanging"
Daniel Morissette
morissette at dmsolutions.ca
Wed Jul 9 09:26:06 EDT 2003
Are you using the latest 3.6.6? There was a similar problem if I
remember well that was fixed somewhere between 3.6.0 and 3.6.6. That
may or may not be the same thing that you ran into.
If you have a systematic way to reproduce this with 4.0 as well then I
would suggest that you file a bug in bugzilla with a mapfile and sample
layer data, and steps to reproduce. If you use a precompiled windows
binary then please also specify where you got it (URL) in the bug.
Daniel
"Christina Biakowski (CCGIS)" wrote:
> Hello,
> we have problems with MapServer, when in quick succession query-requests
> (using GetFeatureInfo) are set. After some requests performance is
> decreasing significantly and we even got CGI-timeouts. Having a look at the
> processes on the server I found that with every request a mapserver-process
> is started. The process then is still running quite a while after the
> query-request has been send, e.g. after many requests many
> MapServer-processes are running simultaneously until the queries do not work
> any more. I wonder why it takes so long until the mapserv-process stops,
> after a query has been passed to MapServer. What might be the problem?
> (We are using 3.6 on Windows)
> Thanks!
> Regards,
> Christina
