[Mapserver-users] polygon lable problem
Aaron D. Hunt
hunt at zedxinc.com
Wed Jul 9 10:48:48 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0031_01C34607.AD88E090
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
Here is shape file I am using Steve, and I am using 4.0b
I am also going to try the code from Vincent.
----- Original Message -----
To: <ed at topozone.com>; <hunt at zedxinc.com>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, July 09, 2003 12:43 AM
Subject: Re: [Mapserver-users] polygon lable problem
> Can you share the data? Concave layers are generally not a problem.
> Polygon labeling uses a technique similar to scanline conversion used to
> compute label points so label points are gauranteed to be "in" the
> polygon. Could be an issue with clipping, or perhaps the label cache
> (you could test that by setting LABELCACHE OFF), but there's no way to
> know without the data and an extent that shows the problem.
> I'll be out until the 14th but will look at it then. BTW What version
> are you using?
> Steve
> Stephen Lime
> Data & Applications Manager
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> "Aaron D. Hunt" <hunt at zedxinc.com> 07/08/03 11:37 AM >>>
> There is a label item but I am overriding the with a TEXT Cool/Wet in
> the class. This is not the first time I have had this problem with
> labeling.
> From: Ed McNierney
> To: Aaron D. Hunt ; mapserver-users at lists.gis.umn.edu
> Sent: Tuesday, July 08, 2003 12:27 PM
> Subject: RE: [Mapserver-users] polygon lable problem
> Aaron -
> Have you checked the attribute table for the data layer, and are you
> SURE that there is indeed a label string for that polygon?
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com / Maps a la carte, Inc.
> 73 Princeton Street, Suite 305
> North Chelmsford, MA 01863
> ed at topozone.com
> (978) 251-4242
> -----Original Message-----
> From: Aaron D. Hunt [mailto:hunt at zedxinc.com]
> Sent: Tuesday, July 08, 2003 12:02 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] polygon lable problem
> With the layer below, Mapserver seams to have a problem labeling
> concave polygons. If you look at the image link below, there is one
> concave polygon in Canada that is not labeled. Is there any way to get
> mapserver to label the polygon.
> http://wcs.zedxinc.com/dy_images/cold.png
> LAYER
> NAME weather
> TYPE polygon
> TRANSPARENCY 60
> LABELITEM "COLOR"
> DATA ""
> STATUS ON
> CLASS
> NAME "NAM"
> COLOR 47 111 111
> TEXT Cool/Wet
> LABEL
> force true
> TYPE TRUETYPE
> FONT arial
> SIZE 12
> POSITION cc
> ANTIALIAS FALSE
> OUTLINECOLOR 255 255 255
> COLOR 0 0 0
> END
> END
> END
> Aaron D. Hunt
> Technical Manager
> ZedX Inc.
> Voice: 814-357-8490
> Fax: 814-357-8499
Content-Type: application/x-zip-compressed;
name="shape.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="shape.zip"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------=_NextPart_000_0031_01C34607.AD88E090--
