[Mapserver-users] imsemu-0.1 and perl mapscript
Lowell Filak lfilak at medinaco.org
Wed Jul 9 16:57:58 EDT 2003
I don't have an answer but I was just about to start using that here and
  have an interest in the solution.
Did you happened to check for any perl 5.6->5.8 porting guides to see if
there are some general issues that may be producing the messages?
Lowell
The following message was sent by Brock Murch
<bmurch at seas.marine.usf.edu> on Wed, 9 Jul 2003 16:27:47 -0400.
> Anyone having success with:
> imsemu.
> When using it on
> perl -v
> This is perl, v5.8.0 built for i386-linux-thread-multi
> I had to chang a line
> my $xml_in = join("",<>);
> to
> my $xml_in = join("",STDIN);
> To get anything al all.... but still seeing all this stuff below in the
> error_logs. Mean anything to anyone?
> Brock
> [Wed Jul 09 16:51:32 2003] [error] [client 131.247.137.155] $name=cmd
> $value=ping
$name=servicename
> $value=catalog
> [Wed Jul 09 16:51:32 2003] [error] [client 131.247.137.155] Can't open
> ServiceName=catalog: No such file or directory at
> /var/www/cgi-bin/com.esri.esrimap.Esrimap line 122.
> [Wed Jul 09 16:51:32 2003] [error] [client 131.247.137.155]  [16:51:32]
[16:51:32] Query:
> ServiceName=catalog
> Service:
[16:51:32] XML:
> <?xml version="1.0"
encoding="UTF-8"?><GETCLIENTSERVICES/>
[16:51:32] Doc:
> ARRAY(0x84fba78)
> [Wed Jul 09 16:51:44 2003] [error] [client 131.247.137.155]
$name=servicename
> $value=S1EX1_TEST
$name=customstream
> $value=False
> [Wed Jul 09 16:51:44 2003] [error] [client 131.247.137.155] Can't open
> ServiceName=S1EX1_TEST\&CustomStream=False: No such file or directory at
> [Wed Jul 09 16:51:44 2003] [error] [client 131.247.137.155]  [16:51:43]
[16:51:43] Query:
> ServiceName=S1EX1_TEST&CustomStream=False
> Service: /var/www/html/tutorial35/s1/s1ex1_test4.map
[16:51:43] XML:
> <?xml version="1.0" encoding="UTF-8"?><ARCXML
version="1.0.1"><REQUEST
> dpi="120"><GET_SERVICE_INFO toc="true"/></REQUEST></ARCXML>!
[16:51:43] Doc:
> ARRAY(0x84fbcc8)
> [Wed Jul 09 16:51:44 2003] [error] [client 131.247.137.155] Can't locate
> auto/mapscript/mapObj/swig_projec.al in @INC (@INC contains:
> /usr/lib/perl5/5.8.0/i386-linux-thread-multi /usr/lib/perl5/5.8.0
> /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi
> /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl
> /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi
> /usr/lib/perl5/vendor_perl/5.8.0 /usr/lib/perl5/vendor_perl .) at
> /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi/mapscript.pm
line 2517
> [Wed Jul 09 16:51:45 2003] [error] [client 131.247.137.155] File does not
> exist: /var/www/html/metadata
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
