[Mapserver-users] Perl Mapscript - equivalent of zoompointmethod..?
Lowell Filak lfilak at medinaco.org
Thu Jul 10 11:32:56 EDT 2003
Actually I recall a discussion with a fellow PerlMapScript user at MUM
who was thinking of "packaging" some of these more frequently requested
routines.
Unfortunately I have a hard time remembering my own name when things are
  busy so I have forgotten who it was.
Would the appropriate person be willing to comment on the status of such
a package?
Thanks.
Lowell
The following message was sent by Eric Bridger <eric at gomoos.org> on Thu,
10 Jul 2003 09:44:41 -0400.
> Ali,
> In the Wiki, mapquakes.pl example:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PerlMapScriptExamples35ex2
there is a function called set_extent() which takes the users mouse
click and zooms the map to that point.  Is that what you need?
> If no zoom is set, $zoom_dir == 0,  then this functions as a pan tool,
recentering the map.
> Steve Lime wrote mapquakes.pl.  I also adapted some javascript of his
into Perl to handle pan direction buttons.  This just adjusts the mouse
click image coordinates which then must be passed to set_exent().
> sub pan_to_map {
>     my ($map, $direction) = @_;
>     my $pansize = .50;
>     my ($x, $y) = (0,0);
>     my $width = $map->{width};
>     my $height = $map->{height};
>     if($direction eq 'n') {
>       $x = ($width-1)/2.0;
>       $y = 0 - ($height * $pansize)/2.0;
>     } elsif($direction eq 'nw') {
>       $x = 0 - ($width * $pansize)/2.0;
>     } elsif($direction eq 'ne') {
>       $x = ($width-1) + ($width * $pansize)/2.0;
>     } elsif($direction eq 's') {
>       $y = ($height-1) + ($height * $pansize)/2.0;
>     } elsif($direction eq 'sw') {
>     } elsif($direction eq 'se') {
>     } elsif($direction eq 'e') {
>       $y = ($height-1)/2.0;
>     } elsif($direction eq 'w') {
>     $x = int($x);
>     $y = int($y);
>     return($x, $y);
> Eric
> At 12:37 PM 07/10/2003 +0100, AMC Story wrote:
> >Hi there everyone,
> >I'm using Perl Mapscript to develop the interface of my application,
and have
> >very kindly been given some existing code to work from from another
member of
> >the list.  The code that I am making reference to is written using PHP
> >Mapscript, so I'm having a little bit of trouble in that not all of
the methods
> >available with PHP Mapscript are available with the Perl version.
> >I'm dealing with my panning buttons at the moment, and the example I
have
> >defines a point object which the new map will zoom to, and then uses the
> >zoompoint method of the map object.  This method isn't available in
Perl, does
> >anyone have any suggestions as to how I might get around this?
Similarly,
> >their zoomin function makes use of the zoomrectangle method...
> >Thanks for any light you can shed on this.
> >Ali
> >_______________________________________________
> >Mapserver-users mailing list
> >Mapserver-users at lists.gis.umn.edu
> >http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
