[Mapserver-users] generate maps in WBMP (for WAP)
Lowell Filak lfilak at medinaco.org
Fri Jul 11 10:29:47 EDT 2003
Okay, my version of GIMP doesn't read WBMP but if yours does can you
view it in GIMP?
Lowell
The following message was sent by Pedro Salazar
<pedro-b-salazar at ptinovacao.pt> on 11 Jul 2003 14:27:31 +0100.
> > If you look at the temp image file does it have a size > 0?
> > If you do a "file" on the temp image file does it identify as the
> > correct type?
> I can't get a conclusion about that because either the generated WBMPs
> by mapserver or the WBMPs I make through GIMP (image application), a
> _file_ reports it as "data". There is no doubt about the "construction"
> of the WBMP (there aren't empty), and I'm not using any transparency
> now.
> regards,
> Pedro Salazar.
> PS
> PGP:0E129E31D803BC61
