[Mapserver-users] Problem using Mapserver
Swaminathan, Gayathri
gayathri at ou.edu
Fri Jul 11 12:29:01 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C347C9.8981F560
Content-Type: text/plain
Hi:
Need more information,
1) What do you mean by "execute command for displaying map" ? Can you brief
how you are doing it?
2)Yes, the tmp directory should be set up as per instructions for the map
images to be created..
3) Questions b and c are again unclear...
Can you give some examples., lines from your code?
Thanks,
Gayathri
-----Original Message-----
From: Suddhasheel Ghosh [mailto:suddhasheel_ghosh at yahoo.com]
Sent: Friday, July 11, 2003 6:16 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Problem using Mapserver
Hello
My name is Suddhasheel Ghosh and I want to use Mapserver for GIS
applications. I have the following setup:
(1) Windows Operating System XP
(2) Apache Server
(3) PHP 4.3.2
(4) Mapserver 3.6
I have completed all the formalities of the mapserver namely putting the
mapserv.exe into the CGI directory etc.
When I want to execute the command for displaying a map it is not doing so..
Why? This gives rise to two questions:
a. Do I have to make a setting for an temporary directory somewhere? If yes
then where
b. When I provide the name of the map in the map file ... Is the directory
virtual or real
c. When I provide the argument of the map file in the QueryString is the
place virtual or real?
Please answer the question
My address is Suddhasheel at yahoo.com <mailto:Suddhasheel at yahoo.com>
Thanks and regards
Suddhasheel GHOSH
Suddhasheel Ghosh
Etudiant
Groupement pour le Developpement de la Teledetection Aerospatiale
8-10 rue Hermes,
Parc Technologique du Canal
31520 Ramonville St. Agne Cedex, Toulouse, France
Mobile: +33 (0)685 692 390
_____
Want to chat instantly with your online friends?
<http://uk.rd.yahoo.com/mail/tagline_messenger/*http://uk.messenger.yahoo.co
m/> Get the FREE Yahoo! Messenger
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=US-ASCII">
<TITLE>Message</TITLE>
<META content="MSHTML 6.00.2800.1170" name=GENERATOR></HEAD>
<BODY>
<DIV><SPAN class=598133817-11072003><FONT face=Arial color=#0000ff
size=2>Hi:</FONT></SPAN></DIV>
<DIV><SPAN class=598133817-11072003><FONT face=Arial color=#0000ff size=2>Need
more information,</FONT></SPAN></DIV>
size=2></FONT></SPAN> </DIV>
<DIV><SPAN class=598133817-11072003><FONT face=Arial color=#0000ff size=2>1)
What do you mean by "execute command for displaying map" ? Can you brief how you
are doing it?</FONT></SPAN></DIV>
<DIV><SPAN class=598133817-11072003><FONT face=Arial color=#0000ff size=2>2)Yes,
the tmp directory should be set up as per instructions for the map images to be
created..</FONT></SPAN></DIV>
<DIV><SPAN class=598133817-11072003><FONT face=Arial color=#0000ff size=2>3)
Questions b and c are again unclear...</FONT></SPAN></DIV>
<DIV><SPAN class=598133817-11072003><FONT face=Arial color=#0000ff size=2>Can
you give some examples., lines from your code?</FONT></SPAN></DIV>
<DIV><SPAN class=598133817-11072003></SPAN> </DIV>
size=2>Thanks,</FONT></SPAN></DIV>
size=2>Gayathri</FONT></SPAN></DIV>
<BLOCKQUOTE style="MARGIN-RIGHT: 0px">
<DIV></DIV>
<DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><FONT
face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> Suddhasheel
Ghosh [mailto:suddhasheel_ghosh at yahoo.com] <BR><B>Sent:</B> Friday, July 11,
2003 6:16 AM<BR><B>To:</B>
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users] Problem
using Mapserver<BR><BR></FONT></DIV>
<DIV>Hello </DIV>
<DIV> </DIV>
<DIV>My name is Suddhasheel Ghosh and I want to use Mapserver for GIS
applications. I have the following setup: </DIV>
<DIV> </DIV>
<DIV>(1) Windows Operating System XP </DIV>
<DIV>(2) Apache Server </DIV>
<DIV>(3) PHP 4.3.2 </DIV>
<DIV>(4) Mapserver 3.6 </DIV>
<DIV> </DIV>
<DIV>I have completed all the formalities of the mapserver namely putting the
mapserv.exe into the CGI directory etc. </DIV>
<DIV> </DIV>
<DIV>When I want to execute the command for displaying a map it is not doing
so.. Why? This gives rise to two questions: </DIV>
<DIV> </DIV>
<DIV>a. Do I have to make a setting for an temporary directory somewhere? If
yes then where </DIV>
<DIV> </DIV>
<DIV>b. When I provide the name of the map in the map file ... Is the
directory virtual or real </DIV>
<DIV> </DIV>
<DIV>c. When I provide the argument of the map file in the QueryString is the
place virtual or real? </DIV>
<DIV> </DIV>
<DIV>Please answer the question</DIV>
<DIV> </DIV>
<DIV>My address is <A
href="mailto:Suddhasheel at yahoo.com">Suddhasheel at yahoo.com</A></DIV>
<DIV> </DIV>
<DIV>Thanks and regards</DIV>
<DIV> </DIV>
<DIV>Suddhasheel GHOSH</DIV>
<DIV> </DIV>
<DIV> </DIV><BR><BR>
<DIV>
<P><FONT size=3><FONT face=Verdana>Suddhasheel Ghosh</FONT><BR></FONT><FONT
face=Verdana><STRONG>Etudiant</STRONG><BR><FONT size=1>Groupement pour le
Developpement de la Teledetection Aerospatiale<BR>8-10 rue Hermes,<BR>Parc
Technologique du Canal<BR>31520 Ramonville St. Agne Cedex, Toulouse,
France<BR>Mobile: +33 (0)685 692 390</FONT></FONT></P></DIV>
<P>
<HR SIZE=1>
<FONT face=Arial size=2>Want to chat instantly with your online
friends? <A
href="http://uk.rd.yahoo.com/mail/tagline_messenger/*http://uk.messenger.yahoo.com/"><B>Get
the FREE Yahoo! Messenger</B></A></FONT> </BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C347C9.8981F560--
