[Mapserver-users] Problem wtih tileindex and queryByRect()
Daniel Lagos
dlagos at vianauta.com
Tue Jul 15 12:48:05 EDT 2003
Hello everybody,
I am using:
redhat 7.1,
php 4.0.6,
configure' '--with-apxs' '--with-mysql' '--enable-dbase' '--enable-ftp'
'--with-freetype-dir=/usr/lib' '--with-png-dir=/usr/lib'
'--with-jpeg-dir=/usr/lib' '--with-tiff-dir=/usr/lib'
'--with-zlib-dir=/usr/lib' '--with-gd' '--x-libraries=/usr/X11R6/lib'
'--x-includes=/usr/X11R6/include' '--with-readline=/usr/include/readline'
'--with-pgsql' '--enable-trans-sid' '--with-regex=system'
php/mapscript 3.5
./configure --with-proj --with-png --with-gdal --with-freetype --with-jpeg
--with-php=/usr/include/php --with-gd --with-apxs=/usr/sbin/apxs
and i trying to use tile shapefile (shp2tile-1.1), all works well, however my
problem are:
1. message Warning when use property DATA and TILEINDEX in the LAYER OBJECT at
MAPFILE:
LAYER
NAME nodoMetro
METADATA
"DESCRIPTON" "Estaciones de Metro"
"RESULT_FIELDS" "ID"
END
TYPE POINT
STATUS OFF
LABELITEM "ESTACION"
LABELMAXSCALE 20000
DATA NodoMetro
TILEINDEX TileNodoMetro
TILEITEM LOCATION
error: Warning: MapServer Error in msTiledSHPOpenFile(): Unable to open a
single tile to use as a template
but if i change and comented DATA parameter:
LAYER
NAME nodoMetro
METADATA
END
TYPE POINT
STATUS OFF
LABELMAXSCALE 20000
-------> #DATA NodoMetro <---------
TILEITEM LOCATION
work fine, but my problem is when i use the function queryByRect() with this
Layer no get results.
i am very confused...any idea??.
Thanks in advance,
PD: sorry by my english.
____________________________________________
Daniel A. Lagos H.
Vianauta S.A.
Lota 2257 Of. 401, Providencia
Santiago, CHILE
Tel: +56 (2) 234 1575
Fax: +56 (2) 234 1578
www.vianauta.com
