[Mapserver-users] Class Expression help
Nick Petersen-Bergeron
bergeron at zedxinc.com
Thu Jul 17 11:22:33 EDT 2003
As a followup, when I quote the column name, I get the error:
Thu Jul 17 11:29:04 2003 - msEvalExpression(): General error message.
Cannot evaluate expression, no item index defined.
While this error seems more pertinent, an Item Index shouldn't be necessary
should it?
At 05:01 PM 7/17/2003 +0200, Vincent Schut wrote:
>Nick,
>jsut a guess, but have you tried it with [LEVEL] and [DAY] single quoted too?
>I think you always need to quote your attribute column names.
>Regards,
>Vincent.
>On Thursday 17 July 2003 16:50, Nick Petersen-Bergeron wrote:
> > I'm trying to do a class based layer structure for a map program I'm
> > writing. I've looked through all of the syntax examples for expressions
> > that I can find, but can't seem to figure out what's wrong.
> > I have around 20 classes in the layer. Essentially the only thing that
> > will differ between classes is the color.
> > I've included an example of one of the classes.
> > CLASS
> > EXPRESSION "(('[TEMP]' eq 'normal') AND ('[PRECIP]' eq
> > 'normal') AND ([LEVEL] eq 0) AND ([DAY] eq 30))"
> > COLOR 50 50 50
> > SIZE 5
> > NAME "normal_city"
> > SYMBOL "circle"
> > LABEL
> > COLOR 50 50 50
> > FONT arial
> > SIZE 12
> > POSITION ur
> > ANTIALIAS TRUE
> > TYPE TRUETYPE
> > END
> > END
> > Can anyone see a problem with this?
> > When I comment out a single expression, the shapefile I'm using defaults to
> > using that class, so I'm guessing that none of the expressions are
> > evaluating to true. However, the dbf for the shape seems to indicate that
> > this should not be the case. The only error being thrown is the following:
> > Thu Jul 17 10:41:37 2003 - msSearchDiskTree(): Unable to access file.
> > Unable to open spatial index for /home/wcs/html/data/countries2.qix. In
> > most cases you can safely ignore this message, otherwise check file names
> > and permissions.
> > Thanks for your help.
System Administrator
ZedX Inc.
369 Rolling Ridge Drive
Bellefonte, PA. 16823
