[Mapserver-users] [Fwd: Maplab for oracle spatial]
Dave McIlhagga
mcilhagga at dmsolutions.ca
Fri Jul 18 07:56:35 EDT 2003
Hi Utaip,
The Oracle Spatial connection is a MapServer issue, and shouldn't have
any impact on MapLab. I'm forwarding to the MapServer List to see if
anyone has ideas on your oracle spatial problem.
Dave
-------- Original Message --------
Subject: Maplab for oracle spatial
Date: Fri, 18 Jul 2003 11:45:49 +0700
To: mcilhagga at dmsolutions.ca
Hello
I have problem when I adding layer from oracle spatial
I use oracle9i and I have recently downloaded Mapserver & MapLab
software and configured
with IIS as well as Apache web server. I could successfully able to run
the demo application of MapServer in both the environments using the ESRI
shape file data. The application is able to do panning, zooming, querying,
layer control, etc. operations. Now as a part of second phase of the
project, I want to access the Oracle Spatial data from MapServer and
publish on browser. We made a trial but failed to achieve the objective. In
this regard, I coding the following map file
LAYER
NAME "Bound"
STATUS ON
DATA "GEOM FROM BOUND USING SRID 90112"
TYPE LINE
CONNECTIONTYPE ORACLESPATIAL
CONNECTION "admin/admin at GisMaejo"
METADATA
"DESCRIPTION" "bounds"
END
#PROJECTION
# "init=epsg:23947"
#END
CLASS
NAME "bounds"
COLOR 255 153 153
TEMPLATE "ttt_query.html"
END
END
I get an error: msDrawMap?()
Can you help me about:
1. How to get PHP_Mapscript.dll with oracle support?
2. Oracle9i already have OCI client dynamic link libraries (the DLLs)?
2. Could you elaborate the procedure for
setting up the configuration Maplab for Oracle OCI.
thank for advance
utaitip at hotmail.com
_________________________________________________________________
STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
http://join.msn.com/?page=features/junkmail
