[Mapserver-users] PHPMapscript
Adam Zornes zornes at athenic.com
Fri Jul 18 14:20:11 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C34D59.3A13A28B
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
All,
=20
            Sorry to be such a bother about this subject, but I have a
problem which is giving me fits. =20
            I have successfully installed php on IIS under windows NT.
I have installed mapserver, and it will run without incident on its own.
            My problem comes when I try to run a php page with
mapscript.  I am unable to load a map.  I can access some other
functions, such as ms_newPointObj, but not ms_newMapObj.
            I have considered every possible angle, but continually get
the following error message, "Fatal error: Due to thread-safety
problems, php_mapscript cannot be used as a 'cgi-fcgi' module. You will
have to reconfigure your PHP as a CGI to run this version of MapScript.
See http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI. in
D:\TreeGuideIntranet\mapserver\frankfort\frankfort.phtml on line 47"
            I have set php to run as cgi as described in several places,
but this is to no avail.  Can anyone help me with this?
=20
Cheers,
Adam Zornes
Athenic Systems
Content-Type: text/html;
	charset="us-ascii"
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C34D37.B24210C0">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0in;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EmailStyle17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
span.GramE
	{mso-style-name:"";
	mso-gram-e:yes;}
@page Section1
	{size:8.5in 11.0in;
	margin:1.0in 1.25in 1.0in 1.25in;
	mso-header-margin:.5in;
	mso-footer-margin:.5in;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Table Normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0in 5.4pt 0in 5.4pt;
	mso-para-margin:0in;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>All,<o:p></o:p></span></font></p>
font-family:Arial'><o:p>&nbsp;</o:p></span></font></p>
font-family:Arial'><span =
style=3D'mso-tab-count:1'>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp=
;&nbsp;&nbsp;&nbsp; </span>Sorry
to be such a bother about this subject, but I have a problem which is =
giving me
fits. <span =
style=3D'mso-spacerun:yes'>&nbsp;</span><o:p></o:p></span></font></p>
;&nbsp;&nbsp;&nbsp; </span>I
have successfully installed <span class=3DSpellE>php</span> on IIS under =
<span
class=3DGramE>windows</span> NT.<span style=3D'mso-spacerun:yes'>&nbsp; =
</span>I
have installed <span class=3DSpellE>mapserver</span>, and it will run =
without
incident on its own. <span =
;&nbsp;&nbsp;&nbsp; </span>My
problem comes when I try to run a <span class=3DSpellE>php</span> page =
with <span
class=3DSpellE>mapscript</span>.<span style=3D'mso-spacerun:yes'>&nbsp; =
</span>I am
unable to load a map.<span style=3D'mso-spacerun:yes'>&nbsp; </span>I =
can access
some other functions, such as <span =
class=3DSpellE>ms_newPointObj</span>, but not
<span class=3DSpellE>ms_newMapObj</span>.<o:p></o:p></span></font></p>
have considered every possible angle, but continually get the following =
error
message, &#8220;</span></font><b><span style=3D'font-weight:bold'>Fatal =
error</span></b>:
Due to thread-safety problems, <span class=3DSpellE>php_mapscript</span> =
cannot
be used as a '<span class=3DSpellE>cgi-fcgi</span>' module. You will =
have to
reconfigure your PHP as a CGI to run this version of <span =
class=3DSpellE>MapScript</span>.
See <a =
href=3D"http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI">htt=
p://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapScriptCGI</a>.
<span class=3DGramE>in</span> <b><span =
style=3D'font-weight:bold'>D:\TreeGuideIntranet\mapserver\frankfort\frank=
fort.phtml</span></b>
on line <b><span style=3D'font-weight:bold'>47&#8221;</span></b><span
style=3D'mso-bidi-font-weight:bold'><o:p></o:p></span></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt;mso-bidi-font-weight:bold'><span =
have set <span class=3DSpellE>php</span> to run as <span =
class=3DSpellE>cgi</span>
as described in several places, but this is to no avail.<span
style=3D'mso-spacerun:yes'>&nbsp; </span>Can anyone help me with =
this?<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt;mso-bidi-font-weight:bold'><o:p>&nbsp;</o:p></span></font></p>
style=3D'font-size:
12.0pt;mso-bidi-font-weight:bold'>Cheers,<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt;mso-bidi-font-weight:bold'>Adam =
Zornes<o:p></o:p></span></font></p>
style=3D'font-size:
12.0pt;mso-bidi-font-weight:bold'>Athenic Systems</span></font><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span></font></p=
</div>
</body>
</html>
------_=_NextPart_001_01C34D59.3A13A28B--
