[Mapserver-users] query dynamic layers...
Rainer Spittel rasp at tzi.de
Tue Jul 22 03:31:47 EDT 2003
     I have a funny problem and I don't know what 'I' am doing wrong. I
have a map file, called "test.map", containing two layers. The user
shall append a new layer to the mapserver on the fly (e.g.
"grp_points"). I am using MapServer 3.6.6 and PHP/MapScript and do the
following stuff:
<?php
function GMapDrawMap()
     $colorId = $gpoMap->addColor(22,222,222);
     $objLayer = ms_newLayerObj($gpoMap);
     $objLayer->set("name",   "gro_layer");
     $objLayer->set("type",   MS_LAYER_POINT);
     $objLayer->set("status", MS_ON);
     $objLayer->set("data",   "./gro_points");
     $objLayer->set("template", "ttt.html");
     $objLayer->setMetaData("DESCRIPTION","Custom features (Points)");
     $objLayer->setMetaData("RESULT_FIELDS","PROG_IN ATTRIBUTE CLASS");
     $objClass = ms_newClassObj($objLayer);
     $objClass->set("name","test");
     $objClass->set("color", $colorId);
     $objClass->set("symbol",1);
     $objClass->set("size",10);
     $objClass->set("template", "ttt.html");
     if ($gbShowQueryResults)
         $img = $gpoMap->drawQuery();
     else
         $img = $gpoMap->draw();
     $url = $img->saveWebImage($gAppletImgFmt, 0, 0, -1);
I inserted this code to the MSMapDrawMap function of the GMAP demo. This
new layer will be displayed correctly, but I am not able to query (!)
objects on this layer :-(
When I store this map-file with the command:
     $gpoMap->save("./test.map");
and open it again and the new point-layer is queryable. Hmmm, what did
I forget?
Why do I have to "append" these layers each time when the map will be
redrawn? Or am I wrong with this presumption...
Thx,
Rainer
Dipl. Inf. Rainer Spittel
TZI - Center for Computing Technologies
Intelligent Systems
University of Bremen
Universitaetsallee 21-23, D-28359 Bremen, GERMANY
Tel: 0421/218-7091 Fax: 0421/218-7196
E-Mail: mailto:rasp at tzi.de
