[Mapserver-users] Error message using PostGis
Gabriel Vieira Ferrari
gabriel at ciasc.gov.br
Wed Jul 23 15:21:49 EDT 2003
Hi listers.
With ours information and others from MS homepage we are able to use
PostGis.
Thanks to all.
----- Original Message -----
To: "Gabriel Vieira Ferrari" <gabriel at ciasc.gov.br>;
<mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, July 22, 2003 5:58 PM
Subject: RE: [Mapserver-users] Error message using PostGis
I wonder if it is a connection issue? Are you getting any connection errors
on your postgis layers. One thing I found was that if my mapserver server ip
wasn't in the pg_hba.conf file then the postgis layer would refuse a
connection to it. More info might be available in your web server's error
logs because for a while mapserver was eating up the error messages that
might occure below what you read on the screen.
Zamil
-----Original Message-----
From: Gabriel Vieira Ferrari [mailto:gabriel at ciasc.gov.br]
Sent: Tuesday, July 22, 2003 3:09 PM
To: Zamil Murji; mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] Error message using PostGis
Hi Zamil.
I included the line and returned the same message.
===>> DATA "the_geom from cidade_p using srid = -1"
Thanks.
Sent: Tuesday, July 22, 2003 12:11 PM
Hi Gabriel,
I had a similar problem not to long ago. You need to be add USING SRID = -1
to the end of your DATA tag. I'm not to sure if it will accept -1 so you
might have to update the SRID field for every geom to a valid one. Hope this
helps.
Thanks
Zamil
Sent: Tuesday, July 22, 2003 8:36 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Error message using PostGis
Hi listers.
Is the first time I'm use Postgres/Posgis with MapServer and receive this
error MSG:
==>> msDrawMap(): Image handling error. Failed to draw layer named
'cidadept0'.
But the original shp file are read without error.
Complementary information:
Postgres/Postgis is: VERSION: 0.7.5 (2003/04/08)
MapServer is:
MapServer version 4.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=TIFF INPUT=EPPL7
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
MAP file:
CONNECTION "user=postgres password=xxx dbname=mapserver host=xxxx"
DATA "the_geom from cidade_p"
I import shp files with:
$ shp2pgsql -d ../mapserver/data/cidade_p cidade_p mapserver|psql -d
mapserver (point data)
$ shp2pgsql ../mapserver/data/politico2001 sc2001 mapserver |psql -d
mapserver (polygon data)
$ shp2pgsql -d ../mapserver/data/politico2001 sc2001 mapserver |psql -d
mapserver=# \dt
List of relations
Schema | Name | Type | Owner
public | cidade_p | table | postgres
public | geometry_columns | table | postgres
public | politicotable | table | postgres
public | sc2001 | table | postgres
public | sc97 | table | postgres
public | spatial_ref_sys | table | postgres
(6 rows)
mapserver-# \d cidade_p
Table "public.cidade_p"
Column | Type | Modifiers
gid | integer |
id | integer |
nm_munic | character varying |
munic_02 | character varying |
ptot2001 | bigint |
the_geom | geometry |
Check constraints: "$1" (srid(the_geom) = -1)
"$2" ((geometrytype(the_geom) =
'POINT'::text) OR (the_geom IS NULL))
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
