[Mapserver-users] some troubles on proj
Yewondwossen Assefa
assefa at dmsolutions.ca
Fri Jul 25 17:03:22 EDT 2003
--------------040804040501050309070705
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Hi There,
We actually has a discussion on this and the latest DM build for
windows have started using the c:\proj\nad directory. We agreed that the
c:/proj/nad was the way to go since It is consistent with other builds.
I think you should keep yours to c:/proj/nad too.
Later,
Pericles S. Nacionales wrote:
>¡Hola, Chen!
>On Fri, 2003-07-25 at 01:39, Chen Fu wrote:
>>Hi!
>>I play with wms these days, and find some troubles in
>>proj.
>>First, why proj data must be save on c:\proj\nad? I
>>have try use PROJ_LIB to point it to other directory,
>>but all get "msProcessProjection(): Projection library
>>error. no system list, errno: 2"
>The directory C:\Proj\NAD is the default directory in Proj's makefile.
>I didn't bother changing it as it makes sense to me. DM Solutions use
>C:\Proj as the PROJ_LIB directory. Perhaps, next time I'll change mine
>to C:\Proj as well.
>As for changing the PROJ_LIB directory, did you try adding a "SetEnv"
>line in your httpd.conf? Something like this should work:
>SetEnv PROJ_LIB "c:/your/proj/lib"
>I think you have to mind your slashes in apache. Also, I appended mine
>right before Section 2 of httpd.conf.
>-Perry N.
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body>
Hi There,<br>
<br>
We actually has a discussion on this and the latest DM build for windows
have started using the c:\proj\nad directory. We agreed that the c:/proj/nad
was the way to go since It is consistent with other builds. I think you should
keep yours to c:/proj/nad too.<br>
<br>
Later,<br>
<br>
Pericles S. Nacionales wrote:<br>
<blockquote type="cite"
cite="mid1059164906.18394.41.camel at arceuthobium.ecology.umn.edu">
<pre wrap="">¡Hola, Chen!
</pre>
<blockquote type="cite">
<pre wrap="">Hi!
proj.
</pre>
</blockquote>
<pre wrap=""><!---->
to C:\Proj as well.
-Perry N.
<a class="moz-txt-link-abbreviated" href="mailto:Mapserver-users at lists.gis.umn.edu">Mapserver-users at lists.gis.umn.edu</a>
<a class="moz-txt-link-freetext" href="http://lists.gis.umn.edu/mailman/listinfo/mapserver-users">http://lists.gis.umn.edu/mailman/listinfo/mapserver-users</a>
</pre>
</blockquote>
<br>
<pre class="moz-signature" cols="$mailwrapcol">--
Assefa Yewondwossen
Software Analyst
Email: <a class="moz-txt-link-abbreviated" href="mailto:assefa at dmsolutions.ca">assefa at dmsolutions.ca</a>
<a class="moz-txt-link-freetext" href="http://www.dmsolutions.ca/">http://www.dmsolutions.ca/</a>
Fax: (613) 565-0925
</pre>
<br>
</body>
</html>
--------------040804040501050309070705--
