AW: [Mapserver-users] WMS GetFeatureInfo
Daniel Morissette morissette at dmsolutions.ca
Wed Jul 30 14:21:43 EDT 2003
As per the WMS spec: specify FEATURE_COUNT=<something> in the URL with a
value corresponding to the max number of results you want.  The default
number of results returned if FEATURE_COUNT is not specified is 1.
If you use the MapScript $layer->getWMSFeatureInfoURL() function then
pass the value via the featureCount argument.
Daniel
Arnulf Christl (CCGIS) wrote:
> Hi Mark,
> seems like nobody wants to answer your question. I cannot either, because
> the GetFeatureInfo works fine with me. Can you specify cour problem in more
> detail?
> Cheers, Arnulf.
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu]Im Auftrag von Howard
> Mark
> Gesendet: Montag, 28. Juli 2003 16:54
> An: mapserver-users at lists.gis.umn.edu
> Betreff: [Mapserver-users] WMS GetFeatureInfo
> Can anybody tell me how to get multiple feature records using the WMS
> request=GetFeatureInfo?
> This is NOT using the map query template!
> I'm only getting one record now when querying a layer containing many
> polygons under the selected point.
> Mark
