[Mapserver-users] handling multiple projections with single map file
Jan Hartmann jhart at frw.uva.nl
Thu Jul 31 06:48:49 EDT 2003
You can use the CGI variable map_projection to set the projection
dynamically from the URL or form. E.g.
http://host.server.com/cgi-bin/mapserv?map=my.map&map_projection=proj=sinu,ellps=clrk66
You *have* to specify an ellips
Jan
Ganesh P wrote:
> Hi all,
> We are working on MapServer version 3.6 and have a problem with handling
> different projections for different images.
> we have images covering various UTM zones from 11 till 17 and others
> too. So presently, for every new projection we create a separate map
> file and depending on the type of image projection, we use the
> corresponding map file with CGI(PHP).
> My concern is Can we have a single map file wherein we shall define all
> the projections and use either one from our script dynamically ?
> If possible, Can someone please send me a sample map file with different
> projections, and also some script as to how to use/call the
> corresponding projections on fly from our script.
> Thanks in advance
> Regards
> Ganesh Pulicherla
> ___________________________________________________
> Download the hottest & happening ringtones here!
> OR SMS: Top tone to 7333
> Click here now: http://sms.rediff.com/cgi-bin/ringtone/ringhome.pl
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
