[Mapserver-users] MapServer on Windows XP and IIS
Ed McNierney
ed at topozone.com
Thu Jul 31 09:44:10 EDT 2003
Jeff -
There's no problem - that's the way it's supposed to work!
You can run MapServer from the command line with the "-v" switch, and you'll get text output. Normally CGI programs are not meant to be run from the command line, and MapServer is no exception.
If you properly configure your Web site to allow users to execute CGI programs, you should be able to type the following in your browser:
http://server.yourdomain.com/mapserv
(replace the server and domain names with your names)
and get the error message:
"No query information to decode. QUERY_STRING not set."
in your browser window.
Until you get to that point, you haven't managed to get a basic CGI program running, so there's no point in doing anything else yet!
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Thursday, July 31, 2003 7:29 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] MapServer on Windows XP and IIS
I installed MapServer on Windows XO and IIS. When i try to execute the
mapserv from the command window (C:\Inetpub\Scripts\MapServ), i have an
error: "This script can only be used to decode form results and should be
initiated as a CGI process via a httpd server ". I tried also to execute the
script from Internet Explorer. The result is a command window displayed then
closed fast.
Any idea about the possible problem ?
Thanks,
Jeff Lacoste
_________________________________________________________________
The new MSN 8: advanced junk mail protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
