[Mapserver-users] (no subject)
Lowell Filak
lfilak at medinaco.org
Thu Jul 31 13:00:15 EDT 2003
If you view lat/long as a point you can query a street layer by using
the "tolerance" on the layer and doing a query.
However I don't believe it returns the "closest", but you should be able
to find discussion on this in the archives.
Lowell
The following message was sent by "Hermie" <hartr at 3logix.com.au> on Thu,
31 Jul 2003 18:43:45 +1000.
> Hi,
> Is there a standard command to access the name of the label/name of the
> closest road/street based on a given lat/long.
> Any assistance would be great.
> Hart Runge
> 3Logix Pty Ltd
> Delivering Total Logistic Solutions
> Ph. 1300 727 100
> Fax 1300 727 101
> Mobile 0402 794198
> mailto:hartr at 3Logix.com.au <mailto:hartrung at remede.com.au>
> http://www.3Logix.com.au <http://www.remede.com.au/>
> This transmission is for the intended addressee only. If you have received
> this transmission in error, please delete the mail and notify the sender.
> The Contents of this e-mail are the opinion of the writer only and are not
> endorsed by 3Logix Pty Ltd unless expressly stated otherwise.
