[Mapserver-users] WMS Client on IIS with MS_MAPFILE variable
problem
Daniel Morissette
morissette at dmsolutions.ca
Thu Jul 31 13:19:46 EDT 2003
Here are two more suggestions:
1- Try setting MS_MAPFILE globally in your server to a relative path,
e.g. MS_MAPFILE = local.map
then create one scripts directory per WMS service. Each directory
will contain only a copy of mapserv.exe plus the local.map for that WMS
service. When you access mapserv.exe in each script directory it will
load the local.map in that directory since MS_MAPFILE is a relative path.
2- If you are setup to compile mapserv.exe you could produce custom
executables for each WMS service in which you would hardcode the mapfile
path.
3- A better long-term solution could be to enhance mapserv.exe so that
if you rename it to for instance mywms1.exe then it looks for a mapfile
with the same basename (mywms1.map) in a directory specified using an
environment variable such as MS_MAPFILE_PATH. So to setup a new WMS
service you would simply make a copy of mapserv.exe under the name of
the new WMS service in your scripts directory.
Daniel
David Graham wrote:
> Hi everyone:
> Here is a tricky one, perhaps someone has solved this problem. I am no
> IIS expert, so there may yet be a simple solution to this.
> We have some WMS serviers running on Linux and they work fine. I have
> hidden the map file with a shell script as suggested in the WMS Server
> documentation.
> [root at commerce1 cgi-bin]# more i3_demo
> #! /bin/sh
> MS_MAPFILE=/var/www/wms.i3.com/mapfiles/i3demo.map
> export MS_MAPFILE
> /var/www/wms.i3.com/bin/mapserv3.7
> And it works great.
> I now need to perform the same functionality on Windows 2000 using IIS.
> I searched around to see if I could set an environment variable to be
> associated with a given script(exe) but could not find a reference or
> dialog box to set anything.
> I then tried windows scripting. I used cscript.exe to execute the
> following jscript script.
> [dave at solar dave]$ more i3image.js
> var WshShell = WScript.CreateObject("WScript.Shell");
> var WshSysEnv = WshShell.Environment("SYSTEM");
> WshSysEnv.Item( "MS_MAPFILE" ) =
> "N:\\wms_data\\mapfiles\\wms1\\i3_Imagery_wms_service.map";
> WshShell.Run( "C:\\Inetpub\\wwwroot\\wms\\wmsserver.exe", 0, true );
> Then I set the IIS to map an empty file I labled wms.i3image to
> C:\WINNT\cscritpt //Nologo <pathto>\i3image.js
> After setting up some permissions, this executed but I have no results.
> The problem is that the script spawns a new shell and send the output to
> that shell which is then not related back to IIS.
> It also accured to me that the new shell might not even have the
> inherited the CGI environment, but I have not tested that either.
> So my question is has anyone cracked this problem? I know I could
> probably do it in perl or python, but I would rather avoid putting
> another package on the system just for a script this small. This is
> supposed to be the first in a bank of machines that will run only
> Mapserver WMS services with no other applications installed. The idea
> is to minimize the amount of software and thus reduce the degredation of
> the Windows system.
> By the way Windows is a prerequisit since we will be serving up a lot of
> data that is compressed in ECW format.
> So if anyone can give me suggestions on how to make this work with
> Windows 2000 provided technology I would greatly apreaciate it.
> Thanks
> Dave Graham
