[Mapserver-users] DEMO HELP
Siki Zoltan siki at bme-geod.agt.bme.hu
Thu Jul 31 18:42:06 EDT 2003
Hi Hong,
Did you change the map_web_imagepath and map_web_imageurl in
demo_init.html?
map_web_imagepath is the full path to your tmp directory
e,g, /var/www/html/tmp
map_web_imageurl is the path from the www server root
e.g. /tmp (if the server root is a /var/www/html)
Good luck
Zoltan Siki
On Fri, 18 Jul 2003, Hong, Sung-Hyuk wrote:
> I have been able to install mapserv 3.5 with DEMO Itasca 3.5
> However, the image is not generated in the /htdocs/tmp directory.  Some
> example of image name is "/tmp/DEMOsb10585493418502.gif"
> Do I have set some special parameters in apache configuration for mapserv to
> use the tmp directory?  Any suggestion?
> Thank in advance.
> Sung
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
