[Mapserver-users] JavaMapServer (JNI-only)
Steve Lime steve.lime at dnr.state.mn.us
Tue Jun 10 14:09:05 EDT 2003
You're definitely correct on the "pure" java implmentation. The webpage
is in need of a facelift. The plan was always to wrap the C version. I
curious as to how your stuff compares with the Swig generated JNI
interface.
Steve
>>> Andrew Collins <andrewrcollins at yahoo.com> 06/10/03 05:37AM >>>
Each
I just released a completely barebones JNI interface to a
compiled MapServer 3.6.3 DLL, along with a ANT-based build
and test environment, at SourceForge:
JavaMapServer 0.5.0
http://sourceforge.net/projects/javamapserver
I am new to making releases at SF. There is currently
no documentation. I didn't include any release notes.
I hope to get some improved code out there, with an example,
soon. I'm untangling an example which can be deployed in a
servlet engine. I'm currently using JavaMapServer inside
a servlet running on JBoss. I'm also working on an MBean
that puts the MapScriptBean into JNDI.
The header documentation in the source files, and the main
project page are misleading... I doubt that there will ever
be a "pure-Java" implementation of MapServer.
For my current needs a JNI interface works just fine.
Andrew Collins - andrewrcollins at yahoo.com
http://profiles.yahoo.com/andrewrcollins/
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
