[Mapserver-users] Using CGI mode without temp-images... theimages are still being created.
    Eduardo Patto Kanegae
    eduardo at linkgeo.com.br
    Mon Jun 16 08:33:43 PDT 2003
Hi.
Thanks everybody.
You were right. After I set STATUS to OFF in all objects of the mapfile, the temp images stopped to appear.
   Peri, there goes the Template-file and the MapFile:
=== TEMPLATE=====
<html>
<head>
<title>LinkGEO - ClickBrasil</title>
	<link rel="stylesheet" type="text/css" href="[app_style1]">
	<link rel="stylesheet" type="text/css" href="[app_style2]">
	<link rel="stylesheet" type="text/css" href="[app_style3]">
	<link rel="stylesheet" type="text/css" href="[app_style4]">
	<link rel="stylesheet" type="text/css" href="[app_style5]">
	<link rel="stylesheet" type="text/css" href="[app_style6]">
	<link rel="stylesheet" type="text/css" href="[app_style7]">
	<script language="javascript">
	//WARNING - this function works on IE only
	function maskNumber(pThis,pKeyCode,pAcceptDecimals,pAcceptNegatives)
	/*use: onkeypress="return maskNumber(this,window.event.keyCode,false, false)"*/
		if ((pKeyCode == 8 || pKeyCode == 13) || (pKeyCode>=48 && pKeyCode<=57) ){
			/*TAB e ENTER ou  n°s */
			return true;
		} else if (pKeyCode==43){
			if (pThis.value.indexOf("-")== 0 && pThis.value.length>1){
				pThis.value = pThis.value.substr(1,pThis.value.length-1);
			} else if (pThis.value.indexOf("-")== 0 && pThis.value.length==1){
				pThis.value = "";
			return false;
		} else if ((pKeyCode==44 || pKeyCode==46) && (pAcceptDecimals==true)){
			/* , ou . */
			if (pThis.value.indexOf(".")<0){
				pThis.value = pThis.value + ".";
			return false;
		} else if (pKeyCode==45 && pAcceptNegatives==true){
			if (pThis.value.indexOf("-")<0){
				pThis.value = "-" + pThis.value;
			return false;
		} else {
			return false;
	</script>
	function do_browse(){
		document.frm_map.mode.value='browse';
	function do_query(){
		document.frm_map.mode.value='nquery';
		window.status = 'Clique num ponto para informações';
	function do_full(){
		// resetar o retangulo envolvente
		document.frm_map.zoomdir.value='0';
		//document.frm_map.imgext.value="-73.991 -33.751 -32.378 5.272";
		document.frm_map.imgext.selectedoption=1;
		document.frm_map.submit();
	function do_zoomin(){
		document.frm_map.zoomdir.value='1';
		window.status = 'Clique num ponto para aproximar';
	function do_zoomout(){
		document.frm_map.zoomdir.value='-1';
		window.status = 'Clique num ponto para afastar';
	function do_pan(){
		window.status = 'Clique num ponto para trazê-lo ao centro';
	function mapplet_apply(name, minx, miny, maxx, maxy, redraw) {
          document.frm_map.imgbox.value = minx + " " + miny + " " + maxx + " " + maxy;
          document.frm_map.imgxy.value = minx + " " + miny;
	  if (redraw) {
		  if (document.frm_map.map_findmuni_class_expression.value=='') {
			  document.frm_map.layer[0].value='';
			  document.frm_map.procurar_por.value='';
        function mapplet_error(message) {
          alert(message);
	function on_submit(){
		if(document.frm_map.select_imgext.value=='-73.991 -33.751 -32.378 5.272'){
			document.frm_map.layer_br_muni.checked=false;
			document.frm_map.layer_br_hidr.checked=false;
		if (!document.frm_map.findmuni.checked){
			document.frm_map.map_findmuni_class_expression.value='';
		if (document.frm_map.findmuni.checked &&
document.frm_map.map_findmuni_class_expression.value==""){
			alert("Digite o nome do município!");
			document.frm_map.map_findmuni_class_expression.focus();
			return false;
		} else {
			document.frm_map.procurar_por.value =
document.frm_map.map_findmuni_class_expression.value;
			return true;
	var leg_height = 0;
	function flip_legend(){
		if (document.frm_map.legend.style.visibility=='hidden'){
			document.frm_map.bt_legenda.value='Ocultar';
			document.frm_map.legend.style.visibility='visible';
			document.frm_map.legend.height=leg_height;
		} else {
			document.frm_map.legend.style.visibility='hidden';
			document.frm_map.bt_legenda.value='Exibir';
			document.frm_map.legend.height="1px";
	/*function mapplet_mouse_moved(a_string,x,y){
		 xval = Number([minx] + (x * (Math.abs([minx]) - Math.abs(([maxx]))) / [mapwidth]));
		 yval = Number([maxy] - (y * (Math.abs([maxy]) - Math.abs(([miny]))) / [mapheight]));
		window.status = "X: " + xval + "/ Y: " + yval;
	</script>
</head>
<body leftmargin="1" topmargin="5" onload="javascript:leg_height=document.frm_map.legend.height;">
<form method="get" action="[program]" name="frm_map" onsubmit="javascript:return on_submit()">
<table border="1" cellpadding="0" cellspacing="0" align="center" class="sideboxtext">
<tr>
	<td colspan="2" align="center" class="sideboxtitle">LinkGEO / ClickBrasil</td>
</tr>
<tr>
	<input type="hidden" name="imgxy" value="299.5 187">
	<input type="hidden" name="imgbox" value="-1 -1 -1 -1">
	<input type="hidden" name="imgext" value="[mapext]">
	<input type="hidden" name="map" value="[map]">
	<!--<input type="hidden" name="savequery" value="true">-->
	<input type="hidden" name="program" value="[program]">
	<!--<input type="hidden" name="map_web_imagepath" value="{map_web_imagepath}">
	<input type="hidden" name="map_web_imageurl" value="{map_web_imageurl}">-->
	<input type="hidden" name="mainsite" value="[mainsite]">
	<input type="hidden" name="app_url" value="[app_url]">
	<input type="hidden" name="app_style1" value="[app_style1]">
	<input type="hidden" name="app_style2" value="[app_style2]">
	<input type="hidden" name="app_style3" value="[app_style3]">
	<input type="hidden" name="app_style4" value="[app_style4]">
	<input type="hidden" name="app_style5" value="[app_style5]">
	<input type="hidden" name="app_style6" value="[app_style6]">
	<input type="hidden" name="app_style7" value="[app_style7]">
	<input type="hidden" name="mode" value="[mode]">
	<input type="hidden" name="zoomdir" value="[zoomdir]">
	<td colspan="2" >
	<table border="0" cellpadding="0" cellspacing="0" width="100%">
	<tr>
		<td class="row0" width="102px"><a href="[mainsite]">LinkGEO</a></td>
		<td align="left" valign="top" class="newspostedby">
		<table border="0" cellpadding="0" cellspacing="0" align="left">
		<tr>
			<td class="newspostedby"> </td>
				<a href="javascript:do_browse();"><img name="BTmode_browse"
	src="[app_url]img/bt_browse.gif" alt="Navegar no mapa" border="0"></a>
			</td>
				<a href="javascript:do_query();"><img name="BTmode_query"
src="[app_url]img/bt_table.gif" alt="Consultar item" border="0"></a>
			</td>
				<input name="redraw" type="image" src="[app_url]img/bt_refresh.gif"
	alt="Atualizar" border="0" onclick="javascript:document.frm_map.zoomdir.value='0';">
			</td>
			<!--<td class="newspostedby">
				<a href="javascript:do_full()"><img name="BTzoomdir_full"
src="[app_url]img/bt_full.gif" alt="Reiniciar Mapa" border="0"></a>
			</td>-->
				<a href="javascript:do_pan();"><img name="BTzoomdir_pan"
src="[app_url]img/bt_pan.gif" alt="Centralizar" border="0"></a>
			</td>
				<a href="javascript:do_zoomin();"><img name="BTzoomdir_in"
src="[app_url]img/bt_zoomin.gif" alt="Aproximar(zoom+)" border="0"></a>
			</td>
				<a href="javascript:do_zoomout();"><img name="BTzoomdir_out"
	src="[app_url]img/bt_zoomout.gif" alt="Afastar(zoom-)" border="0"></a>
			</td>
				<input name="zoomsize" type="text" title="Grau de Zoom" size="1"
value="[zoomsize]" onkeypress="return maskNumber(this,window.event.keyCode,false, false)"
class="field_textbox">
			</td>
				<select name="imgext" id="select_imgext"
				onchange="javascript:rs=on_submit();if (!rs)
return;document.frm_map.mode.value='browse';document.frm_map.zoomdir.value='0';document.frm_map.submit
();" class="field_selectbox">
				<option value="[mapext]">(zoom para...)</option>
				<option value="-73.991 -33.751 -32.378 5.272">B R A S I L</option>
				<option value="-73.991 -13.693 -46.061 5.272">NORTE</option>
					<option value="-73.991 -11.144 -66.619 -7.117">...AC-
Acre</option>
					<option value="-73.801 -9.814 -56.097 2.247">...AM-
Amazonas</option>
					<option value="-54.876 -1.236 -49.876 4.437">...AP-
Amapá</option>
					<option value="-58.898 -9.841 -46.061 2.591">...PA-
Pará</option>
					<option value="-66.806 -13.693 -59.774 -7.969">...RO-
Rondônia</option>
					<option value="-64.646 -1.580 -58.886 5.272">...RR-
Roraima</option>
				<option value="-48.755 -18.349 -32.378 -1.042">NORDESTE</option>
					<option value="-38.237 -10.501 -35.152 -8.812">...AL-
Alagoas</option>
					<option value="-46.629 -18.349 -37.340 -8.532">...BA-
Bahia</option>
					<option value="-41.435 -7.856 -36.992 -2.784">...CE-
Ceará</option>
					<option value="-48.755 -10.261 -41.795 -1.042">...MA-
Maranhão</option>
					<option value="-38.765 -8.303 -34.793 -6.027">...PB-
Paraíba</option>
					<option value="-41.358 -9.482 -32.378 -3.804">...PE-
Pernambuco</option>
					<option value="-45.993 -10.941 -40.391 -2.746">...PI-
Piauí</option>
					<option value="-38.582 -6.983 -34.969 -4.831">...RN-Rio
Grande do Norte</option>
					<option value="-38.249 -11.568 -36.391 -9.515">...SE-
Sergipe</option>
				<option value="-61.633 -24.068 -45.696 -5.168">CENTROESTE</option>
					<option value="-48.287 -16.051 -47.307 -15.500">...DF-
Distrito Federal</option>
					<option value="-53.251 -19.499 -45.907 -12.395">...GO-
Goiás</option>
					<option value="-58.167 -24.068 -50.922 -17.166">...MS-Mato
Grosso do Sul</option>
					<option value="-61.633 -18.042 -50.224 -7.349">...MT-Mato
Grosso</option>
					<option value="-50.742 -13.467 -45.696 -5.168">...TO-
Tocantins</option>
				<option value="-53.110 -25.312 -39.665 -14.233">SUDESTE</option>
					<option value="-41.879 -21.301 -39.665 -17.891">...ES-
Espírito Santo</option>
					<option value="-51.046 -22.922 -39.856 -14.233">...MG-
Minas Gerais</option>
					<option value="-44.983 -23.427 -40.848  -20.663">...RJ-Rio
de Janeiro</option>
					<option value="-53.110 -25.312 -44.161 -19.779">...SP-São
Paulo</option>
				<option value="-57.644 -33.751 -48.023 -22.516">SUL</option>
					<option value="-54.619 -26.716 -48.023 -22.516">...PR-
Paraná</option>
					<option value="-57.644 -33.751 -49.691 -27.080">...RS-Rio
Grande do Sul</option>
					<option value="-53.836 -29.351 -48.328 -25.955">...SC-Santa
Catarina</option>
				</select>
			</td>
				<b>Escala</b> = 1:[scale]
			</td>
		</tr>
		</table>
		</td>
	</tr>
	</table>
	</td>
</tr>
<tr class="sideboxtext">
	<td align="center" class="sideboxtext" valign="middle">
		<img alt="Barra de Escala" src="[program]?map=[map]&mode=scalebar&mapext=[minx]+
[miny]+[maxx]+[maxy]">
	</td>
		<input type="checkbox" name="layer" value="findmuni" id="findmuni" [findmuni_check]
>Procurar município:<input type="text" name="map_findmuni_class_expression"
value="[map_findmuni_class_expression]" maxlength="30" size="20" class="field_textbox">
		<input type="hidden" name="procurar_por" value="[procurar_por]">
	</td>
</tr>
<!-- v - MAPA -->
<tr>
	<td colspan="2" align="center" class="sideboxtext">
		<table border="0" cellpadding="0" cellspacing="0" align="0" >
		<tr>
			<td align="center" class="sideboxtext" valign="top">
				<table border="1" cellspacing="0" cellpadding="0" class="rightpanel"
align="center">
				<tr>
				<td>
				<applet codebase="[app_url]java/mapplet" code="mapplet.class"
width="600" height="375" name="mapplet" mayscript>
					<!--<param name="image" value="http://[host]{img}">-->
					<param name="image" value="http://[host][program]?map=
[map][get_layers]&mode=map&zoomsize=[zoomsize]&zoomdir=[zoomdir]&mapext=[minx]+[miny]+[maxx]+
[maxy]&size=600+375&map_findmuni_class_expression=[map_findmuni_class_expression]">
					<param name="verbose" value="off">
					<param name="thickness" value="2">
				</applet>
				</td>
				</tr>
				</table>
			</td>
			<td valign="top" class="newspostedby" align="center">
align="center" width="130px">
				<tr><td colspan="2" class="sideboxtext" align="center">
					<input name="ref" type="image" src="[program]?map=[map]
[get_layers]&mode=reference&mapext=[minx]+[miny]+[maxx]+[maxy]" border="1" alt="Clique para centralizar">
				</td></tr>
				<tr>
					<td class="sideboxtext">
					<input type="checkbox" name="layer" value="br_rvia"
[br_rvia_check] id="layer_br_rvia">Rodovias</td>
				</tr>
				<tr>
					<input type="checkbox" name="layer" value="br_fvia"
[br_fvia_check] id="layer_br_fvia">Ferrovias</td>
				</tr>
				<tr>
					<input type="checkbox" name="layer" value="br_sede"
[br_sede_check] id="layer_br_sede">Sedes municipais</td>
				</tr>
				<tr>
					<input type="checkbox" name="layer" value="br_hidr"
[br_hidr_check] id="layer_br_hidr">Hidrografia</td>
				</tr>
				<tr>
					<input type="checkbox" name="layer" value="br_muni"
[br_muni_check] id="layer_br_muni">Estados</td>
				</tr>
				<tr>
					<input type="checkbox" name="layer" value="br_uf"
[br_uf_check] id="layer_br_uf" >Regiões</td>
				</tr>
				<tr>
align="center"><b>Legenda</b></td>
				</tr>
				<tr>
					<td class="sideboxtext" align="center">
						<input type="button" class="button"
name="bt_legenda" id="bt_legenda" value="Ocultar" onclick="javascript:flip_legend()"><br>
						<img src="[program]?map=[map][get_layers]
&mode=legend&mapext=[minx]+[miny]+[maxx]+[maxy]" border="0" alt="Legenda" id="legend" name="legend">
					</td>
				</tr>
				<tr>
					<td align="center" colspan="2" class="sideboxtext">
						<a href="http://mapserver.gis.umn.edu"
target="_show">
						<img src="[app_url]img/by_mapserver.jpg"
border="0" alt="This site is Powered by MapServer [version]">
						</a>
					</td>
				</tr>
				</table>
			</td>
		</tr>
		</table>
	</td>
</tr>
<!-- ^ - MAPA -->
</table>
</form>
</body>
</html>
=== TEMPLATE =====
=== MAPFILE ======
NAME clickbr_ptbr_
STATUS OFF
SIZE 600 375
EXTENT -73.991 -33.751 -32.378 5.272
UNITS DD
SHAPEPATH "data"
SYMBOLSET "etc/br_symbols.sym"
IMAGECOLOR 255 255 255
#@#IMAGETYPE GIF
#IMAGEQUALITY 100 #4JPG
WEB
	EMPTY "/linkgeo/clickbrasil/qry_fail.ptbr.html"
	ERROR "/linkgeo/clickbrasil/error.ptbr.html"
	HEADER "br_header.html" # qry - 1
	TEMPLATE "clickbrasil_app.ptbr.html"
	FOOTER "br_footer.html"
	MINSCALE 10000
	MAXSCALE 35000000
	#@#IMAGEPATH "set in clickbrasil.ptbr.php" #caminho físico das imagens geradas
	#@#IMAGEURL "set in clickbrasil.ptbr.php"
	IMAGEPATH ""
	IMAGEURL ""
	#@#LOG "clickbrasil.ptbr.log"
END
QUERYMAP
  SIZE 300 187.5
  STATUS OFF
  STYLE HILITE
  COLOR 0 0 255
END
REFERENCE
	IMAGE "img/br_reference.gif"
	SIZE 100 62
	STATUS OFF
	COLOR -1 -1 -1
	OUTLINECOLOR 255 0 0
	MAXBOXSIZE 99
END
LEGEND
	KEYSIZE 15 12
	LABEL
		TYPE BITMAP
		SIZE SMALL
		COLOR 0 0 0
	END
	STATUS OFF
END
SCALEBAR
	OUTLINECOLOR 0 0 0
	LABEL
		COLOR 0 0 0
		SIZE SMALL
	END
	STYLE 0
	SIZE 300 3
	COLOR 0 0 0
	UNITS KILOMETERS
	INTERVALS 3
	TRANSPARENT FALSE
	STATUS OFF
END
LAYER
	NAME "br_uf"
	TYPE POLYGON
	STATUS OFF #DEFAULT
	DATA "br_uf"
	CLASSITEM "REGIAO"
	CLASS
		NAME "Norte"
		EXPRESSION "NORTE"
		OUTLINECOLOR 46 92 92
		COLOR 0 192 0
	END
	CLASS
		NAME "Nordeste"
		EXPRESSION "NORDESTE"
		COLOR 192 192 192
	END
	CLASS
		NAME "Centroeste"
		EXPRESSION "CENTROESTE"
		COLOR 255 128 128
	END
	CLASS
		NAME "Sudeste"
		EXPRESSION "SUDESTE"
		COLOR 255 255 128
	END
	CLASS
		NAME "Sul"
		EXPRESSION "SUL"
		#TEMPLATE "qry_br_uf.html"
		COLOR 128 128 255
	END
END
LAYER
	NAME "br_uf_anno"
	NAME "br_uf"
	TYPE ANNOTATION
	STATUS OFF#ON
	DATA "br_uf"
	LABELITEM "SIGLAUF"
	CLASSITEM "SIGLAUF"
	LABELMINSCALE 2500001
	CLASS
		EXPRESSION /./
		COLOR -1 -1 -1
		LABEL
			COLOR 0 0 0
			TYPE BITMAP
			SIZE MEDIUM
			POSITION CC
			PARTIALS FALSE
		END
	END
END
LAYER
	NAME "br_muni"
	TYPE POLYGON
	STATUS OFF
	DATA "br_muni"
	MAXSCALE 16000000
	CLASSITEM "NOMEUF"
	HEADER "br_muni_header.html"
	TEMPLATE "br_muni_tpl.html"
	FOOTER "br_muni_footer.html"
	CLASS
		NAME "RS"
		EXPRESSION "RIO GRANDE DO SUL"
		OUTLINECOLOR 129 129 129
		COLOR 208 208 255
	END
	CLASS
		NAME "SC"
		EXPRESSION "SANTA CATARINA"
		COLOR 187 187 255
	END
	CLASS
		NAME "PR"
		EXPRESSION "PARANA"
		COLOR 151 151 255
	END
	CLASS
		NAME "SP"
		EXPRESSION "SAO PAULO"
		COLOR 255 255 170
	END
	CLASS
		NAME "RJ"
		EXPRESSION "RIO DE JANEIRO"
		COLOR 255 255 128
	END
	CLASS
		NAME "MG"
		EXPRESSION "MINAS GERAIS"
		COLOR 255 255 34
	END
	CLASS
		NAME "ES"
		EXPRESSION "ESPIRITO SANTO"
		COLOR 217 217 0
	END
	CLASS
		NAME "MS"
		EXPRESSION "MATO GROSSO DO SUL"
		COLOR 255 179 179
	END
	CLASS
		NAME "GO"
		EXPRESSION "GOIAS"
		COLOR 255 151 151
	END
	CLASS
		NAME "DF"
		EXPRESSION "DISTRITO FEDERAL"
		COLOR 255 81 81
	END
	CLASS
		NAME "TO"
		EXPRESSION "TOCANTINS"
		COLOR  255 15 15
	END
	CLASS
		NAME "MT"
		EXPRESSION "MATO GROSSO"
		COLOR 215 0 0
	END
	CLASS
		NAME "BA"
		EXPRESSION "BAHIA"
		COLOR 234 235 238
	END
	CLASS
		NAME "SE"
		EXPRESSION "SERGIPE"
		COLOR 218 220 224
	END
	CLASS
		NAME "AL"
		EXPRESSION "ALAGOAS"
		COLOR 201 204 209
	END
	CLASS
		NAME "PE"
		EXPRESSION "PERNAMBUCO"
		COLOR 183 187 193
	END
	CLASS
		NAME "PB"
		EXPRESSION "PARAIBA"
		COLOR 167 172 180
	END
	CLASS
		NAME "RN"
		EXPRESSION "RIO GRANDE DO NORTE"
		COLOR 153 158 168
	END
	CLASS
		NAME "CE"
		EXPRESSION "CEARA"
		COLOR 145 150 162
	END
	CLASS
		NAME "PI"
		EXPRESSION "PIAUI"
		COLOR 128 134 149
	END
	CLASS
		NAME "MA"
		EXPRESSION "MARANHAO"
		COLOR 116 122 139
	END
	CLASS
		NAME "RO"
		EXPRESSION "RONDONIA"
		COLOR 149 255 149
	END
	CLASS
		NAME "AC"
		EXPRESSION "ACRE"
		COLOR 0 251 0
	END
	CLASS
		NAME "AM"
		EXPRESSION "AMAZONAS"
		COLOR 0 217 0
	END
	CLASS
		NAME "AM"
		COLOR 0 217 0
	END
	CLASS
		NAME "PA"
		EXPRESSION "PARA"
		COLOR 0 192 0
	END
	CLASS
		NAME "AP"
		EXPRESSION "AMAPA"
		COLOR 0 166 0
	END
	CLASS
		NAME "RR"
		EXPRESSION "RORAIMA"
		COLOR 0 136 0
	END
END
LAYER
	NAME "br_muni_anno"
	NAME "br_muni"
	TYPE ANNOTATION
	STATUS OFF
	DATA "br_muni"
	LABELITEM "NOME"
	CLASSITEM "NOME"
	LABELMAXSCALE 2500000
	LABELMINSCALE 1125000
	CLASS
		EXPRESSION /./
		COLOR -1 -1 -1
		LABEL
			COLOR 64 64 64
			TYPE BITMAP
			SIZE TINY
			POSITION AUTO
			PARTIALS FALSE
			BUFFER 1
		END
	END
END
LAYER
	NAME "br_muni_anno"
	NAME "br_muni"
	TYPE ANNOTATION
	STATUS OFF
	DATA "br_muni"
	LABELITEM "NOME"
	CLASSITEM "NOME"
	LABELMAXSCALE 1124999
	CLASS
		EXPRESSION /./
		COLOR -1 -1 -1
		LABEL
			COLOR 64 64 64
			TYPE BITMAP
			SIZE SMALL
			POSITION AUTO
			PARTIALS FALSE
			BUFFER 1
		END
	END
END
LAYER
	NAME "br_muni_anno"
	NAME "br_muni"
	TYPE ANNOTATION
	STATUS OFF
	DATA "br_muni"
	LABELITEM "NOME"
	CLASSITEM "NOME"
	LABELMAXSCALE 249999
	CLASS
		EXPRESSION /./
		COLOR -1 -1 -1
		LABEL
			COLOR 64 64 64
			TYPE BITMAP
			SIZE MEDIUM
			POSITION AUTO
			PARTIALS FALSE
			BUFFER 1
		END
	END
END
LAYER
	NAME "br_hidr"
	TYPE LINE
	STATUS OFF
	DATA "br_hidr"
	MAXSCALE 10500000
	CLASS
		NAME "Hidrografia"
		COLOR 0 0 187
	END
END
LAYER
	NAME "br_sede"
	TYPE POINT
	STATUS OFF
	DATA "br_sede"
	CLASS
		NAME "Sedes municipais"
		COLOR 32 32 32
		SYMBOL 'SEDE'
		SIZE 2
	END
END
LAYER
	NAME "br_fvia"
	TYPE LINE
	STATUS OFF
	DATA "br_fvia"
	CLASSITEM "DESCRICAO"
	CLASS
		NAME "Bitola 1,0m"
		EXPRESSION "FERROVIA EM TRAFEGO BITOLA 1.00M"
		COLOR 128 128 0
		SYMBOL 'FVIA_BIT1'
	END
	CLASS
		NAME "Bitola 1,6m"
		EXPRESSION "FERROVIA EM TRAFEGO BITOLA 1.60M"
		COLOR 128 0 128
		SYMBOL 'FVIA_BIT16'
	END
	CLASS
		NAME "Bitola Mista"
		EXPRESSION "FERROVIA EM TRAFEGO BITOLA MISTA"
		COLOR 221 0 0
		SYMBOL 'FVIA_MISTA'
	END
	CLASS
		NAME "Suspensa"
		EXPRESSION "FERROVIA COM TRAFEGO SUSPENSO"
		COLOR 137 90 68
		SYMBOL 'FVIA_SUSP'
	END
	CLASS
		NAME "F.Planejada"
		EXPRESSION "FERROVIA PLANEJADA"
		COLOR 122 142 245
		SYMBOL 'FVIA_PLAN'
	END
END
LAYER
	NAME "br_rvia"
	TYPE LINE
	STATUS OFF
	DATA "br_rvia"
	CLASSITEM "CLASSIF_MT"
	CLASS
		NAME "Duplicada"
		EXPRESSION "DUPLICADA"
		COLOR 166 0 0
	END
	CLASS
		NAME "Em duplicação"
		EXPRESSION "EM DUPLICACAO"
		COLOR 113 0 0
		SYMBOL 'RVIA_EMDPL'
	END
	CLASS
		NAME "Implantada"
		EXPRESSION "IMPLANTADA"
		COLOR 179 129 27
		SYMBOL 'RVIA_IMPL'
	END
	CLASS
		NAME "Em implantação"
		EXPRESSION "EM IMPLANTACAO"
		COLOR 223 112 0
		SYMBOL 'RVIA_EMIMP'
	END
	CLASS
		NAME "Pavimentada"
		EXPRESSION "PAVIMENTADA"
		COLOR 170 102 205
	END
	CLASS
		NAME "Em pavimentação"
		EXPRESSION "EM PAVIMENTACAO"
		COLOR 255 15 135
		SYMBOL 'RVIA_EMIMP' ##########
	END
	CLASS
		COLOR 255 15 135
		SYMBOL 'RVIA_EMIMP'
	END
	CLASS
		NAME "R.Planejada"
		EXPRESSION "PLANEJADA"
		COLOR 0 255 64
	END
	CLASS
		NAME "Leito natural"
		EXPRESSION "LEITO NATURAL"
		COLOR 0 128 128
		SYMBOL 'FVIA_SUSP' #######
	END
	CLASS
		NAME "Balsa"
		EXPRESSION "BALSA"
		COLOR 128 255 255
	END
END
LAYER
	NAME "br_rvia_anno"
	NAME "br_rvia"
	TYPE ANNOTATION
	STATUS OFF
	DATA "br_rvia"
	LABELITEM "SIGLA"
	CLASSITEM "SIGLA"
	LABELMAXSCALE 1000000
	LABELMINSCALE 100000
	CLASS
		EXPRESSION /./
		COLOR -1 -1 -1
		LABEL
			ANGLE AUTO
			COLOR 90 90 90
			TYPE BITMAP
			SIZE TINY
			POSITION AUTO
			PARTIALS FALSE
			BUFFER 1
			MINDISTANCE 200
		END
	END
END
LAYER
	NAME "findmuni"
	TYPE POLYGON
	STATUS OFF
	DATA "br_muni"
	CLASSITEM "NOME"
	CLASS
		EXPRESSION /./
		COLOR 255 0 0
	END
END
END
=== MAPFILE ======
At 11:11 PM 6/13/2003 -0300, you wrote:
>following some tricks from the mapserver users meeting, I've ported a
>MapServer CGI application to one that does not use temporary image files.
>the parameters map_web_imagepath and map_web_imageurl were set as an empty
>value ("") inside the mapfile,
>and the template file of the application has no mention of these
>parameters too.
>I've ported the objects [img], [scalebar], [ref] and [legend] to CGI URLs
>to avoid the use of temp-images.
>However, each time I do an interation to the application, 4 image files
>are created at the same path of the application/mapfile.
You need to set STATUS OFF for the whole map file.
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich at GreenwoodMap.com
(307) 733-0203
http://www.GreenwoodMap.com
----- Original Message -----
From: "Pericles S. Nacionales" <nacional at cbs.umn.edu>
To: "Eduardo Patto Kanegae" <eduardo at linkgeo.com.br>
Cc: "mapserver-users" <mapserver-users at lists.gis.umn.edu>
Sent: Saturday, June 14, 2003 2:15 AM
Subject: Re: [Mapserver-users] Using CGI mode without temp-images... theimages are still being created.
> Hi Eduardo,
> Steve and others probably know more about this than me but I'm wondering
> if you can send your template file.  Chances are we'll be able to point
> out inconsistencies in it.
> Cheers!
> Perry
> > files.
> > empty value ("") inside the mapfile,
> > parameters too.
> > URLs to avoid the use of temp-images.
> > files are created at the same path of the application/mapfile.
> > So, why are these files being created?
> > thanks
> > http://www.linkgeo.com.br
> Pericles S. Nacionales <nacional at biosci.cbs.umn.edu>
> University of Minnesota
***Fim da Mensagem / End of Message ***
More information about the MapServer-users
