[Mapserver-users] RE: TIFF-Display
Olaf Knopp oknopp at kartago.de
Wed Jun 18 08:54:50 EDT 2003
thanks for your help.
I managed the problem as followed: I loaded the TIFF with Manifold 5.0 and
exported it as a TIFF (without editing).
Now it works!!
Olaf
----- Original Message -----
From: "Andrés Collao" <collao_andres at hotmail.com>
To: <mapserver-users at lists.gis.umn.edu>
Cc: <oknopp at kartago.de>
Sent: Tuesday, June 17, 2003 9:04 PM
Subject: [Mapserver-users] RE: TIFF-Display
> Hi,
> I'm working with RASTER and the tif was made with ESRI - Arcview, then
> rename the .TIFW file to .WLD. Uses Photoshop to convert the tif file to
> GRAYSCALE
> Mapserver 3.6.4 is not working with 24 or 16 bit files, only with 1bit.
> >Hello,
> >i have got a problem with the display of a tiff-image. Mapserver shows a
> >white map (and produces a white .png), but navigation is possible, the
> >square on the refenenz map is ok and scale/scalebar also. There is no
> >difference if the tiff is black/white (1 bit) or 8 bit, it never shows an
i
> >get no error message from mapserver.
> >When i use another tiff from another project it works!!
> >The tiff was made with IrfanView (no compression, 256 Colors (counted
16),
> >8 Bit):
> >Here a part of my mapfile:
> >LAYER
> >    NAME "Hintergrund"
> >    DATA "Stadtplan.tif"
> >    TYPE RASTER
> >    OFFSITE 1
> >    STATUS ON
> >END
> >Thanks for your help!
> >Olaf
> Atte.
> Andrés Collao.
> andres at mapserver.cl
> "El hombre es un Dios cuando sueña y un mendigo cuando reflexiona".
> :-- Il peggior nemico del succeso è la pauta del fallimiento
> :-- El peor enemigo del éxito es el miedo al fracaso
> _________________________________________________________________
> Charla con tus amigos en línea mediante MSN Messenger:
> http://messenger.yupimsn.com/
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
