[Mapserver-users] Custom Projects
Benjamin Wragg bwragg at tpg.com.au
Thu Jun 19 10:47:45 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0008_01C336C1.60F62D00
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi list,
If I need to add a custom projection to mapserver I'm I correct in
saying I can just define it correctly and add it to the bottom of say
the /usr/local/share/proj/esri file, give it a unique number and then
referance it in the mapfile as follows:
PROJECTION
    "init=esri:CustomNumber"
END
where CustomNumber is the unique number choosen. Is there anything wrong
with this?
Thanks,
Benjamin
Content-Type: text/html;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<TITLE>Message</TITLE>
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR></HEAD>
<BODY>
<DIV><SPAN class=3D187414414-19062003><FONT face=3DArial size=3D2>Hi=20
list,</FONT></SPAN></DIV>
<DIV><SPAN class=3D187414414-19062003><FONT face=3DArial=20
size=3D2></FONT></SPAN>&nbsp;</DIV>
<DIV><SPAN class=3D187414414-19062003><FONT face=3DArial size=3D2>If I =
need to add a=20
custom projection to mapserver I'm I correct in saying I can just define =
it=20
correctly and add it to the bottom of say the /usr/local/share/proj/esri =
file,=20
give it a unique number and then referance it in the mapfile as=20
follows:</FONT></SPAN></DIV>
size=3D2>PROJECTION</FONT></SPAN></DIV>
<DIV><SPAN class=3D187414414-19062003><FONT face=3DArial =
size=3D2>&nbsp;&nbsp;&nbsp;=20
"init=3Desri:CustomNumber"</FONT></SPAN></DIV>
size=3D2>END</FONT></SPAN></DIV>
<DIV><SPAN class=3D187414414-19062003><FONT face=3DArial size=3D2>where =
CustomNumber=20
is the unique number choosen. </FONT></SPAN><SPAN =
class=3D187414414-19062003><FONT=20
face=3DArial size=3D2>Is there anything wrong with =
this?</FONT></SPAN></DIV>
size=3D2>Thanks,</FONT></SPAN></DIV>
size=3D2>Benjamin</FONT></SPAN></DIV></BODY></HTML>
------=_NextPart_000_0008_01C336C1.60F62D00--
