[Mapserver-users] mapserv doesn't work
=?gb2312?q?Chen=20Fu?=
novalet at yahoo.com.cn
Wed Jun 25 00:26:52 EDT 2003
Hi All!
By the help of the pals on the list, i finally make
mapserver work on my linux box. I have also learned a
lot of linux and apache in the discussion.
Thank you!!!
--- Thorsten Fischer <thfischer at mapmedia.de>
µÄÕýÎÄ£º> On Tue, 2003-06-24 at 09:10, Chen Fu wrote:
> > It didn't generated any image at all. I change
> > map_web_imagepath to many directory, but just
> can't
> > find any image at there. But if i try the itasca
> > advance demo -- the one with "mode=map", it work
> nice.
> The webserver process is running with the access
> rights of a certain
> user. That user must be able to write image files to
> that directory.
> Apart from that, you need to set IMAGEPATH and
> IMAGEURL in your mapfile
> to fitting values.
> > But in this advance demo, query file still need to
> be
> > written when we do a query of object on map. So
> the
> > query will be failed for mapserv didn't generate
> the
> > query file.
> I think you are mixing up map images and query files
> here. In your
> setting, you are producing map image files, like in
> .png or .gif format.
> It is indeed possible to save the staus of a query
> to a file, but that
> has nothing to do with a map image.
> hth,
> thorsten
Remote Scensing Satellite Ground Station
Chinese Academy of Science
_________________________________________________________
Do You Yahoo!?
ÍøÁµµÄÚ¹ÊÍ£ºÕæÇ黹ÊÇ·Å×Ý£¿
http://cn.rd.yahoo.com/mail_cn/tag/?http://cn.surveys.yahoo.com/netlove
