[Mapserver-users] SHPTREE Odd behavior
Kieran J. Ames
kames at keyspanenergy.com
Sun Mar 2 12:35:05 EST 2003
I've been experimenting with shptree and seeing remarkable performance
boosts (on point and line shapefiles). However, I've found some odd
behavior now with polygons.
I'm rendering polygons that take quite a while to come up (mapserver
cgi). I then use shptree and get the following error message:
msDrawShape(): General error message. Only polygon shapes can be drawn
using a POLYGON layer definition.
If I then delete the associated .qix files, the map again renders.
I'm using mapserver
MapServer version 3.6.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=TTF SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=SHAPEFILE
SHPTREE is dated 11/01/00 09:48a 131,122 bytes
...appreciate any help.
Kieran
